View Poll Results: How did you install your Eibach Pro Kit?
Just installed the springs: no alignment
12.82%
Installed the springs & performed alignment at the same time
17.95%
Installed the springs; performed alignment later
41.03%
Installed springs & camber kit (please post which kit below)
28.21%
Voters: 39. You may not vote on this poll
Eibach Pro-Kit: Camber kit or not?
Old Nov 23, 2008 | 10:04 PM
AndrewDDS's Avatar
AndrewDDS
For those of you dropped on Eibachs, who just installed the springs and who added a camber kit? For those of you who didn't get a camber kit, when did you do an alignment? How close to spec did you get? For those of you with a camber kit, which one did you go with?
Old Nov 24, 2008 | 12:37 AM
HamstersG's Avatar
HamstersG
SPC camber kit which is just resold as the Eibach. Part #72260 for rear. When the front comes out it will be part #72135.
Old Nov 24, 2008 | 02:03 AM
G37_6MT's Avatar
G37_6MT
Just dropped on Eibach yesterday... pending SPC camber kit for the rear and will get alignment then... also will be purchasing the SPC front camber kit too once it comes out.
I have mad negative camber in the rear after the drop O_o
Old Nov 24, 2008 | 02:40 AM
Skyline-LEXY's Avatar
Skyline-LEXY
subs
Old Nov 24, 2008 | 10:33 PM
w0ady's Avatar
w0ady
ya bump for info on alignment specs AFTER eibachs WITHOUT camber kits please.
id recommend waiting a couple weeks after the drop before the alignment to give the springs time to settle.
Old Nov 24, 2008 | 11:05 PM
Skyline-LEXY
Madeinchina any input how the alignments went?
Old Nov 24, 2008 | 11:07 PM
Blackjack's Avatar
Blackjack
+1. Definitely give them a couple of weeks to settle. My H-Techs settled after a few weeks and a good mountain run.
Old Nov 25, 2008 | 04:33 PM
w0ady's Avatar
w0ady
you can also do a bunch of figure 8s in a parking lot to help load them up.
Old Nov 25, 2008 | 08:19 PM
bfranks's Avatar
bfranks
For what it's worth, I dropped my 08 G35S on eibachs today (no camber kit), and listed below is the camber after an alignment.
FL: -1.6
FR: -1.8
RL: -1.8
RR: -1.6
Old Nov 25, 2008 | 08:22 PM
AndrewDDS's Avatar
AndrewDDS
FL: -1.6
FR: -1.8
RL: -1.8
RR: -1.6
I'm assuming you meant G37S. Did you have the alignment done at the same time as the spring install? I suppose they gave you the camber specs before the alignment, did they? How was the toe-in?
Old Nov 25, 2008 | 09:24 PM
bfranks's Avatar
bfranks
Nope....G35S, which is why I prefaced it with "For what it's worth". Since no one else had posted numbers without the camber kit I figured I'd list mine to give you some idea of what you would be looking at.
Edit: Added alignment sheet
Attached Thumbnails Eibach Pro-Kit: Camber kit or not?-alignment.jpg
Old Nov 26, 2008 | 08:17 AM
w0ady's Avatar
w0ady
^thats not bad at all for camber. appreciate the posting! the toe on the rear tires is a bit high though. thats what will really wear your tires out. id recommend rear toe arms at the least.
Old Nov 26, 2008 | 08:38 AM
bfranks's Avatar
bfranks
It's not as bad as I thought, but I'll still be putting a camber / toe kit on. This is also right after the springs were put on, but I doubt they will change significantly. I'll post up a new alignment sheet, once I let them settle and get the kit installed. It will be interesting to see just how much it does change when the springs settle.
Old Nov 26, 2008 | 02:24 PM
AndrewDDS's Avatar
AndrewDDS
I'm having my Eibachs installed sometime next week. A few weeks after that, I'll have the dealership perform an alignment. I'm going to have them print off before and after alignment readings, sp I'll post up the results as soon as it's all done.
Old Nov 27, 2008 | 11:24 AM
w0ady's Avatar
w0ady
thanks andrew. ya i know the 35s had a bit of variance car to car. some people were able to get back in spec and some werent. so far it looks like rear toe is the only thing really out of spec.
