Tein S/H techs v.s. Eibach pro kit
Old Nov 23, 2008 | 12:14 AM
CHEFONE's Avatar
CHEFONE
I was wondering which lowering springs are better? Tein S/H techs or Eibach Pro Kit? And i was wondering if i will need a SPC camber kit both front and rear or just rear?
Please post pics for comparison
Old Nov 23, 2008 | 01:13 AM
xlack's Avatar
xlack
Eibach all the way!!
some people may say u dont need camber kit but id go both front and rear. when its time for u to change ur tires u'll understand.
Old Nov 23, 2008 | 03:40 AM
synergy10's Avatar
synergy10
FWIW - I'm going with the Eibach Pro-Kits. I based my decision on the reviews I've read in this forum. I love the subtle, yet noticeable drop (specially in the front).
Also, If you're worried about tire wear, as long as you go to an alignment shop after you install the springs, you will be fine. They will be able to set the toe within spec.
Old Nov 23, 2008 | 03:53 AM
jnguyen's Avatar
jnguyen
yeah true but with every aftermarket spring you still cannot get it back to factory spec and only a camber kit can do that. on eibach your dont need it but its recommended and on tein i think you definately need it
Old Nov 23, 2008 | 05:48 AM
synergy10's Avatar
synergy10
I was only talking about toe settings. As for camber, I agree, you will need a camber kit to get it back to factory spec. Unless you're saying that toe cannot be adjusted back to spec without a camber kit?
OP - you might want to subscribe to this thread
https://www.myg37.com/forums/showthr...eibach+springs
Old Nov 23, 2008 | 06:01 AM
myk1013's Avatar
myk1013
I ordered the Eibachs as well. Nothing but great reviews.
The Tein's were too low for me. And yes, go with camber kits, either one you end up with.
Old Nov 23, 2008 | 11:16 PM
CHEFONE's Avatar
CHEFONE
Well the Eibachs sound great but if i decide to get the spc camber kit will it be nessecary to get both front and rear kits or just the rear?
Old Nov 24, 2008 | 12:29 AM
HamstersG's Avatar
HamstersG
Front camber kits not out yet. Couple of us posted alignment results with Eibach Pro-kit and rear camber kits here: https://www.myg37.com/forums/brakes-and-suspension/185326-eibach-pro-kit-results-close-up-pictures-of-results.html. See post 25 and 27.
Old Nov 24, 2008 | 12:42 AM
xlack's Avatar
xlack
get both, u cant go wrong
Old Nov 24, 2008 | 02:08 AM
The1andOnly's Avatar
The1andOnly
Wait until Tein realeses their springs for the G37 at the beginning of the year. The drops should be around if not the same height. The ride quality should be better since the will be made to handle the G37 added weight, and that should help to ease up a little on the shocks & struts.
Old Nov 24, 2008 | 10:35 PM
w0ady's Avatar
w0ady
tein is saying january 09 for their springs. might get the eibachs until then lol.
OneSickBlackG
Jan 6, 2016 08:49 AM
TheIvoryG
Sep 23, 2015 02:06 AM
EnYcee-G
Sep 3, 2015 04:35 PM
Andyg90
Sep 2, 2015 06:10 PM
