Spacer help!
Old Aug 25, 2008 | 07:55 PM
LAG37's Avatar
LAG37
Spacer help!
hey everyone,
as most of you know i am lowered on H&R race springs.
My wheels are stock sport rims(19 inch)
I have been considering spacers on the rear, and i was wondering what size i should get.
I want an aggresive offset, but because of my low height i do not want to risk rubbing.
Will 10mm be sufficient to be alligned with the fender?
thanks for your help
-LAG37
Old Aug 25, 2008 | 08:10 PM
LAG37's Avatar
LAG37
bump!
Old Aug 25, 2008 | 08:12 PM
TerribleONE453's Avatar
TerribleONE453
there was a thread somewhere about spacers.. i believe he did more than 10MM on the rear.. i will try to find it. who are you going to order the spacers from?
Old Aug 25, 2008 | 08:17 PM
LAG37's Avatar
LAG37
my friend with a 335 is ordering them with me from some guy ill let u kno tomorrrow
Old Aug 26, 2008 | 02:17 AM
LAG37's Avatar
LAG37
hello?
bump?
will 10 mm make me flushed?
Old Aug 26, 2008 | 03:03 AM
Lou@Amplified's Avatar
Lou@Amplified
You can do 15mm. Make sure you order the 15mm hub centric spacers otherwise, if you get the regular spacers, you'll risk your rears poppin off while your driving since the bolts are not long enough
Old Aug 26, 2008 | 03:18 AM
LAG37's Avatar
LAG37
if i order 10mm spacers their is a chance of my rear wheels popping off?
Old Aug 26, 2008 | 03:23 AM
myk1013's Avatar
myk1013
If I remember it correctly, GiGGaPlease had 25mm spacers but on stock height. His wheels looked like it was sticking out a bit. But with your H&R's it should look good.
But don't take my word for it. I have bad memory.
Old Aug 26, 2008 | 03:24 AM
Lou@Amplified
When i had my stocks with 8mm spacers, i was only able to turn the lug nuts 3.5 full turns which is very unsafe.
Old Aug 26, 2008 | 03:42 AM
LAG37's Avatar
LAG37
so what do u suggest i do?
are the 10mm not good?
im confused...
Old Aug 26, 2008 | 04:25 AM
Lou@Amplified
cancel your 10mm order and order a 15mm or 20mm HUB CENTRIC SPACER from your friend.
Its safer than doing a 10mm without getting replacement studs that are longer
Old Aug 26, 2008 | 09:33 AM
Kidcane's Avatar
Kidcane
Florida G Club
You can get 10mm with the longer studs too. 10mm will put them close, 15mm is about perfect. Either will need longer studs or you will die.
Old Aug 26, 2008 | 10:53 AM
06mtg35's Avatar
06mtg35
call wheel fix it in Miami and ftlauderdale, they are experts on Spacers, and could even make them custom for your application. they fixed some of my wheels in the past, and do all types of work for wheels and spacers so they should be able to help you!!
Old Aug 26, 2008 | 12:58 PM
LAG37's Avatar
LAG37
thanks for the help!
Kojack
Oct 9, 2015 05:53 PM
faze2988
Oct 7, 2015 12:05 AM
VQCrew
Sep 26, 2015 01:19 PM
nbast
Sep 14, 2015 12:39 PM
Thirty_Seven
Sep 14, 2015 09:07 AM
