Need Help removing nut.... Driving me Crazy
Old May 16, 2008 | 01:10 PM
jtree007's Avatar
jtree007
Well I was going to install my new coilovers last night... but no dice.
The nut that holds in the lower part of the shock and spring assembly on the G37 would not budge for me. I tried everything up to Air Tools. Nothing would make it budge. I Have not clue what more to do other then to take it to Forged or get a more powerful impact wrench. Soaked it in PB Blaster as well
I am so frustrated... I have never had a problem this bad before.......
Does anyone else think that 120 Ft/lb. is a little excessive for that nut? I could see 80 or so.. but 120 is a lot.
Any ideas? anyone have any problems like this?
jtree007's Avatar
jtree007
The offending nut is circled in red
Attached Thumbnails Need Help removing nut.... Driving me Crazy-fsu-8-problem.jpg
Old May 16, 2008 | 03:08 PM
Mike6mt's Avatar
Mike6mt
I think you should stop before you strip it. =(
Old May 16, 2008 | 03:11 PM
Kidcane's Avatar
Kidcane
Florida G Club
I used a gun on mine so I did not realize it was so tight. Good luck.
Old May 17, 2008 | 05:28 AM
13adzo6's Avatar
13adzo6
I had the same problem when i installed my BC's. I tried EVERYTHING! I ended up breaking my impact socket, so I hacked it off. Then trying to find a nut that size was a PITA. Finally ended up ordering one from my Infiniti dealer. $2.55+ a $2.00 freight charge for that nut. Good luck!
Old May 18, 2008 | 12:00 AM
UNV-IT46's Avatar
UNV-IT46
impact gun here....
Old May 18, 2008 | 12:40 AM
Dieseldoug22's Avatar
Dieseldoug22
Pretty sure I just used a 1/2" breaker bar here.
Old May 18, 2008 | 10:25 AM
jtree007's Avatar
jtree007
Good to know I am not the only one having a problem. I think the nut on my car got over torqued a the factory...
Old May 27, 2008 | 10:24 PM
sharif@forged's Avatar
sharif@forged
Just bring it over here. Yup, they are tight....I wouldnt even attempt it without impact tools.
Let us know if you need any help.
redlinernyc
Feb 29, 2016 11:06 PM
SLEV3N
General Tech Questions
Oct 17, 2015 05:58 PM
abretz89
Aug 20, 2015 11:58 PM
Cr0tchf4i
Aug 19, 2015 03:52 PM
