Nitrogen in tires
Old Mar 3, 2008 | 02:54 PM
quart's Avatar
quart
Nitrogen in tires
Obviously most of us, if not all are limited by the lack of filling stations, but has anyone thought about using nitrogen in their tires? The GT-R will only be available with this and supposidly in order for a dealer to be cerified to sell, service and maintain the GT-R they will be required to be able to refill nitrogen tires.
A few tuners are doing it, as are Ferrari and some other high-end manufacturers, but I am wondering if there is a noticible difference and if it is deemed a worth mod, if there are any sources or ways one could fill their tires with minimal investment and access to filling stations.
Old Mar 3, 2008 | 03:17 PM
speedracer g37's Avatar
speedracer g37
my 37 came filled with nitrogen and im sure many more on this board have nitrogen also. the valvecaps have a nitro logo and there should be a pamphlet in the glovebox if your car came with it stock...im pretty sure the only advantage is that tire pressue doesnt fluctuate with temperature.
Old Mar 3, 2008 | 03:23 PM
Gyoza's Avatar
Gyoza
Nitrogen in the tires adds about 10hp/25tq to the wheels.
j/k- Since Nitrogen molecules are relatively large compared to a normal mix of air, adding pure nitrogen is supposed to keep the tires at the correct pressure for longer.
I wouldnt pay any extra to have this done.
Old Mar 3, 2008 | 03:52 PM
quart's Avatar
quart
Obviously I am not looking to invest in any new hardware, but am wondering if those that have cars that came with nitrogen in their tires have a particular package, or if it is a dealer thing.
I have a fully loaded Journey with sport package and don't recall this being an option. The only thing I don't have is AWS, is this an active steering package option?
Old Mar 3, 2008 | 04:19 PM
Gyoza's Avatar
Gyoza
the air we breath (and what is in your tires) is 78% nitrogen. The only hardware needed is a nitrogen tank at the dealer or auto shop.
Old Mar 3, 2008 | 05:05 PM
speedracer g37
there wasn't an extra charge for the nitro listed on the sticker. i don't have 4was either, so i don't think it is part of a package. if you want nitrogen in your tires, any large national chain like discount tire, ntb, etc. should have nitrogen available for a charge.
Old Mar 3, 2008 | 07:25 PM
LAZY TURBO's Avatar
LAZY TURBO
what will nitrogen actually do to the tires??
todd92's Avatar
todd92
Air is 78% N2. Most of the rest is 02, which is a bigger molecule than N2. Using nitrogen has nothing to do with the size of the molecule. Both air and N2 expand and contract exactly the same amount with temperature changes, according to the equation PV=nRT. It doesn't matter what the gas is.
Pure nitrogen is dry, meaning it is free of water vapor. Water vapor in air will condense out below freezing, such that humid air used to fill a tire will have a large pressure drop when the water vapor condenses. Compressed air that has been dried is every bit as good as N2 at avoiding this.
Old Mar 3, 2008 | 11:23 PM
Da Hashi's Avatar
Da Hashi
nitro keeps the tire pressure more constant....as you drive the tire heats up and when this happens regular air in you tire expands and raises your tire pressure......nitro expands less under heat so your tire pressure dosent raise as much as normal air.....thus you having more grip .....we use nitro for racing and seems to help with tire wear also...but for the street i dont think its needed
Old Mar 4, 2008 | 12:09 AM
31337's Avatar
31337
I think Costco puts Nitro in all the tires you buy from them.
Old Mar 4, 2008 | 12:44 AM
speedracer g37
internet info. straight dope (found in most city papers) take it for what its worth. http://www.straightdope.com/columns/070216.html
Old Mar 4, 2008 | 05:50 AM
todd92's Avatar
todd92
The only part they got right was the water vapor.
Nitrogen is a fatter molecule...no it's skinnier. Oxygen attacks the rubber...what about the oxygen and UV sunlight on the outside? Makes the tires fireproof on planes...LOL.
Old Mar 4, 2008 | 11:08 AM
maxipad96's Avatar
maxipad96
Mine came with Nitrogen as well. Don't know if it was a sport package thing or what. I have fancy blue valve covers that came on the car as well to alert everyone as to how cool I am because I have nitrogen.
Old Mar 4, 2008 | 03:49 PM
shumby's Avatar
shumby
Also less rooling resistance with Nitrogen. Not much but it is true. For an example take 2 cans of apple juice remoe the juice from one and no the other. roll both down an incline the one with nothing in it will get there first because the air offers less resistance than the juice.
Old Mar 4, 2008 | 07:08 PM
todd92's Avatar
todd92
Sigh
