Bleeding Brakes
Bleeding Brakes
Hi there, im replacing my rotors and pads this week, i was just wondering from a video that i watch, that the person bled the brakes before taking the calipers off. If that necessary to do or is it only a regular maintenance of the brake fluid.
Thank you in advance
Brakes should be flushed/bled every 2-3 years regardless of mileage. More so if you're in a very humid environment. Brake fluid absorbs moisture which can lead to internal corrosion and brake fade under heavy use. It's cheap maintenance if you do it yourself.
Flushing the fluid while doing the brakes is a good idea. The wheels are already off.
Track Bandit
Nov 10, 2014 10:51 PM
