Help RWD Rear Swaybar on an AWD
Old Jan 26, 2021 | 07:35 PM
steveng37's Avatar
steveng37
I have a RWD rear sway bar to put on my X sedan. What do I need to make it compatible with my car, if anything? Brackets?
Old Jan 27, 2021 | 08:37 AM
RMB5190's Avatar
RMB5190
Your brackets may fit. can't say for sure since mine came with brackets. It's only 4-6 bolts; can find out in about 15 minutes.
Old Jan 27, 2021 | 04:49 PM
Carboy37's Avatar
Carboy37
Play it safe and replace the brackets. The AWD bar is 16mm and the RWD one is 24mm. It's safe to assume that the bushings can't fit a bigger than original size and it's best to use the sway bar as designed.
Old Feb 28, 2022 | 11:11 AM
zmancb7's Avatar
zmancb7
did you end up swapping out the brackets as well? looking to replace my sway bar next month and trying to get all pieces together. My sway bar didn't come with bushings, bolts, nuts, or brackets. do you have part #s for what you used and did you swap out end links as well?
Old Feb 28, 2022 | 12:51 PM
SonicVQ's Avatar
SonicVQ
I just checked and the rear sway bar brakets (54614-EG000) are all the same for all models of the G35/G37/Q50/Q70 and a few others.
The sway bar bushing will have a different sized ID, depending on the size of the bar.
7Head
Feb 2, 2017 04:05 AM
mjnoles1
Jan 15, 2016 03:38 PM
RhiNoKiLL
Sep 18, 2010 02:00 AM
motobonsai
May 3, 2010 01:33 PM
bsowhat1
Mar 29, 2010 09:57 PM
