Coil spring isolator help
Old Dec 20, 2020 | 10:31 AM
backman_66's Avatar
backman_66
Does anyone have a spare rear TOP coil spring isolator laying around that they can take measurements of for me please? I'm wanting to get a small spacer to place above it to raise the rear up a little bit, without switching back to stock springs and cutting the isolator.
I was looking on this website at the Style A option and thinking it could fit inside the top of the isolator and give a small ride height boost.
https://www.suspension.com/universal-coil-spring-isolators.asp
Any help with measurements would be appreciated because I don't want to take my spring back off again to check lol
Old Dec 21, 2020 | 05:03 PM
Hugh Jorgens's Avatar
Hugh Jorgens
Any isolator you buy, you'll need to shave the spring seat's diameter to fit.
For reference, the rear spring is 98.5mm (3.88") ID.
There's a russian seller on ebay selling 20mm (!!!) spacers that fit right up. But...20mm is a lot.
I recommend using a 3-3/4" ID to start. Not much shaving needed. And the lip OD matches the spring well.
https://www.energysuspensionparts.com/9.6101
the 9.6101 is 3/8 height. Duno what height you want.
Old Dec 21, 2020 | 05:11 PM
backman_66's Avatar
backman_66
Thanks for the info man!
UCLAG37
Apr 21, 2020 04:33 PM
Legendman92
Apr 18, 2018 07:35 PM
kdawg8526
17
Dec 9, 2016 09:32 PM
JohnnysG
Mar 29, 2013 02:54 PM
