change springs on BC BR Coilover
Old Nov 13, 2019 | 12:54 AM
evendale's Avatar
evendale
I have installed BC BR coilover for over a year, but still cannot get used to the stiff ride feel. I tried to adjust the damping to the softest but cannot feel much difference. I am going to upgrade the springs to Swift and also lower the spring rate to 10k/8k. Will it make the ride quality as comfortable as the stock? Will the lower rate springs destroy the coilover?
Any information would be greatly appreciated.
Old Nov 13, 2019 | 01:40 AM
slartibartfast's Avatar
slartibartfast
I have 10/8 on my MeisterR, feels barely stiffer than the stock S springs.
Old Nov 13, 2019 | 09:55 AM
PNW_IPL's Avatar
PNW_IPL
That should work well. However I would not have the dampers on softest. Maybe 2-3 from soft with the new springs. Dampers can handle 2-3kg difference either way
Old Nov 13, 2019 | 01:05 PM
evendale's Avatar
evendale
How about the handling? Better than stock?
Old Nov 13, 2019 | 01:08 PM
evendale's Avatar
evendale
do you mean a 8k spring with hardest dampening is equal to 10-11k spring soft dampening?
Old Nov 13, 2019 | 01:19 PM
MerakiAutoworks's Avatar
MerakiAutoworks
Your #1 Infiniti Vendor!
Yes it would be better.
-Josh
Old Nov 13, 2019 | 02:09 PM
PNW_IPL's Avatar
PNW_IPL
No. Not comparible.
Old Nov 15, 2019 | 05:32 PM
evendale's Avatar
evendale
Anyone knows do I need to buy the rear bucket spring adapter?
Old Nov 15, 2019 | 05:48 PM
PNW_IPL's Avatar
PNW_IPL
Quite possible. The gen 1 came with it but gen 2 got fatter springs. So maybe. Post a pic of your rear spring and see if you have one already in your spring buckets. If not and you want to run swift rear then yes you'll need it
Old Nov 15, 2019 | 06:41 PM
evendale's Avatar
evendale
Thanks, that is helpful. I just checked rear bucket and it is fat spring ( bottom and top diameter is different). I think I need to buy a pair.
Old Nov 17, 2019 | 12:37 AM
evendale's Avatar
evendale
Hi, Josh, Do you sell the swift spring for BC coilover?
hockeyzbh
Dec 8, 2017 07:35 PM
buffpatel
Aug 22, 2014 08:34 PM
soundmike
Dec 28, 2012 08:32 AM
OB G
Nov 16, 2012 09:49 AM
bmckenney
Nov 5, 2012 10:17 AM
