VDC and Slip lights on after brake change?
Hello, I have a 2008 G37 and my brakes was getting bad. So I went to Auto Zone and ordered OE Brembo brakes. (I don't have the sport package) I installed the brakes, greased the pins, I opened the bleeder valve slightly when pushing back in the pistons so the fluid did not push back into the master cylinder. Then put everything back together, pressed the pedal to the floor a few times to fill back up the brake fluid in the calipers then topped off my fluid back to the max line. I turned on the car and my VDC light and my Slip light are suck on and I do not know how to fix this problem. I have checked all the fuses they are good. fluid is all topped off, no leaks. I test drove the car and the breaks work good.
I am running out of options and hoped that you guys might know something else I can try so I can fix this problem. The lights never came on before unless my tires were spinning.
I also did tire rotation but I don't think this would affect it.
Thanks everybody.
Thanks everybody.
Nope no damage to anything, Checked over everything and I figured I would try the fuse again and left it out for 30 min and then put back in and started car and now I have no lights and everything works again. I think that is what you was trying to say also Teahead and thank you both for responding.
