VDC light and "SLIP" light
Old Oct 15, 2015 | 01:13 PM
Tomhuff23's Avatar
Tomhuff23
I have an 2009 G37 Journey and recently my VDC(Off) and "SLIP" lights come on when I accelerate. Sometimes my "Brake" light will flash and go off once I'm up to 40-50 mph. I'm not accelerating aggressive, just normal driving conditions??
Does anyone know why this happens?
Old Oct 15, 2015 | 01:29 PM
Thirty_Seven's Avatar
Thirty_Seven
Check your brake fluid. It could be low. If so, top it off or do a flush.
Old Oct 15, 2015 | 08:00 PM
Tomhuff23's Avatar
Tomhuff23
Thanks Thirty_Seven. Low brake fluid will cause my VDC light and "SLIP" lights to come on as well. I can see that for the "Brake" light? Just curious?
Old Oct 15, 2015 | 10:29 PM
Thirty_Seven
I was referring to the VDC and Slip lights. The brake light flashing is odd.
If you're fluid levels are fine, there may be an issue with the ABS Sensor. Have you tried resetting the ECU and seeing if the lights come back?
Old Dec 29, 2015 | 07:28 PM
G Coop's Avatar
G Coop
I've been having the same problem for a while now. My VDC and Slip light keep coming on and I almost wrapped my car around a tree in the rain the other day
Old Dec 29, 2015 | 07:55 PM
Dj1ofDet's Avatar
Dj1ofDet
I've had this happen twice in my G, and it was a bad wheel sensor both times.
Old Dec 30, 2015 | 04:27 PM
G Coop's Avatar
G Coop
How much does it cost to replace the wheel sensor ?
Old Dec 30, 2015 | 11:37 PM
Vicious37x's Avatar
Vicious37x
I believe for the G and other infiniti products the wheel sensor or wheel speed sensor is part of the wheel hub assembly so they will need to replace the whole hub. I got my wheel hub replaced under warranty for free. Check your brake pads also. Those lights are identical low pads which lead to low brake fluid.
Old Mar 9, 2016 | 11:43 AM
ajmr2's Avatar
ajmr2
Greetings.
I had the same thing happen in my recently purchased 2008 G37S at low speeds around town. Alarming for sure. This forum has been very helpful with my research and I went the "start with the simple stuff" route. Checked the brake and clutch fluid levels, which were both down quite a bit, topped them off and it's be fine at all speeds and braking conditions ever since. WHEW!
Today I inspected the brake pads, which are probably the originals since it only has 40K miles on it and was obviously babied by the previous owner. The fronts are about half way (7/32), the rears are a bit more worn, but my mechanic said the fronts are fine and the rears are OK for another 5K miles. Will do them all at my next oil & filter change. Any advice on non dusting ceramic brake pads would be appreciated.
AJ
Old Nov 26, 2022 | 11:45 PM
Itztahmeed's Avatar
Itztahmeed
Question ???
how did you figure out which wheel had the bad sensor????
ANMVQ
Dec 8, 2016 04:55 PM
2K1 6T8
Oct 6, 2015 07:40 PM
Emper
Oct 3, 2015 11:51 PM
4DRZ
Sep 29, 2015 11:25 PM
DennisG37
Sep 24, 2015 12:22 AM
