Help - brake pad size
Old May 7, 2019 | 06:07 PM
zippy33's Avatar
zippy33
Hi.
I just ordered brakes and now wonder if i ordered wrong pads.
i have a 2009 infiniti g37x coupe awd.
my rotors are 320 on front and 307 on rear.
for pads i'm seeing 888,905 and 1287.
i ordered the 905 and 1287 but think i maybe should have got the 888 instead.
i looked all over here and everything was sedan related and i only seen one mention of 1287.i just went by an old email when i ordered parts before,but then remembered at some point the parts were wrong but that mighta been at the beginning when i ordered and got the 330's front and back.
thanks.
Old May 8, 2019 | 07:50 PM
It's a bit tricky on AWD base coupes, they changed to the 330/330 rotors in 2010, yours are the same in rotors & pads as the G37 sedan (non-sport) w/ the 320/307 rotors, if you got pads for the 320/307 combo you're good, if you ordered the 330/330 you're not.
Old May 8, 2019 | 10:14 PM
zippy33's Avatar
zippy33
Pad size
I ordered the 905 and 888 but i think the 1288 or 1287 might be the ones too.there’s a very small size difference.it shouldn’t be this hard to get the info.and the fact that there are two different sizes depending on what part of the year your car was made,makes it impossible to get info from drop down menus on brake websites.
Old May 8, 2019 | 10:53 PM
What pad brand/model are you referring to?
Old May 8, 2019 | 11:51 PM
zippy33's Avatar
zippy33
pad brand
i ordered from Max Brakes.
Old May 9, 2019 | 09:57 AM
Went on their site and couldn't pull up part #s, said to contact them (sorry, if I can't find it online I'm done). There's only 1 caliper for that front rotor size and one for the rear, so there shouldn't be any pad mix-ups on their end, but ???
O2nv84
Jun 17, 2019 08:19 AM
twin_snails
May 17, 2019 06:16 PM
symatt
24
Feb 21, 2019 12:43 PM
Luky
Feb 3, 2019 11:24 AM
Scottfreidel
Dec 4, 2018 11:08 PM
