abs and slip light on
My abs and slip lights come on when I am braking at low speeds and it doesn't come on instantly some times. I can drive on the freeway at 80+ and it doesnt come on. I have a 2011 g37 sedan rwd and the tires are staggered but im pretty sure that's fine. I have topped off brake fluid and changed brake pads already and this problem still occurs. Any ideas before i take it to the dealership?
I see people running staggered setups with even wider tires in the back but I haven’t heard anyone complain that these lights on come though
It's not just width or stagger, you have to figure the appropriate aspect ratio to keep overall diameter within 3% of the OE number.
Stock front is 225/50-18, rear is 245/45-18 giving overall diameters of 26.68 & 26.86 inches, respectively. Your diameters are 25.75 & 26.03 inches, respectively. Appropriate 19" tire specs are 245/40-19 and 285/35-19 to stay within 0.5% of OE diameter. 275/35-19 also works for the rear and is a more common size.
There are numerous tire calculators on the web.
OBD Fusion with the $15 add-on for Enhanced diagnostics will do the trick:
https://youtu.be/g3bMDC_41qc
