Snapped a banjo bolt
Old Mar 12, 2019 | 12:22 AM
PNW_IPL's Avatar
PNW_IPL
Snapped a banjo bolt on the front caliper.
anyone know the torque spec of the banjo bolt?
i think the brake fluid made me over do it.
pls haaalp.
im so close to being done.
Old Mar 12, 2019 | 02:52 PM
PNW_IPL's Avatar
PNW_IPL
Trq spec is 12 ft lbs splains why.
thanks.
Old Mar 12, 2019 | 09:43 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Been there done that... On my motorcycle when I installed SS lines. It used a double banjo bolt at the lever master. I used a torque wrench.
Second time around, i used the torque spec good'n'tight. No issues... Sold the bike 5 years later with 80+K miles. 12 ft lb isn't very tight. About as tight as the spec was on the bike I think. Main goal is to keep it from leaking and/or going loose.
Old Mar 13, 2019 | 01:56 PM
PNW_IPL's Avatar
PNW_IPL
I got lucky. When it snapped somehow to torque backout the portion stuck in the caliper and i was able to easly unscrew that. New banjo should be here in the morning.
thanks bro
Old Mar 14, 2019 | 04:44 PM
JSolo's Avatar
JSolo
Just say no!!!!!
^^Ditto too. There was a tiny bit of out sticking out. Was around to undo gently by hand. Annoying when you try to follow directions but end up breaking things.
Old Mar 14, 2019 | 08:07 PM
PNW_IPL's Avatar
PNW_IPL
thanks for making me feel better.
got this project done finally!
bled the system still feels a bit spongy. Just happy to be rolling again. Will bleed again soon.
heres the carnage.
Calg37USMC
Aug 22, 2020 03:10 PM
ARogers502
Jan 19, 2019 01:52 PM
warped ideas
Engine, Intake and Exhaust
64
May 23, 2016 06:55 PM
Gspinin
Mar 21, 2014 08:16 PM
JohnnysG
Mar 29, 2011 10:24 PM
