Bottom of front strut bolt stripped
Old Nov 24, 2018 | 11:26 AM
VTREEZY's Avatar
VTREEZY
hey guys, I installed 3/4 of my coil overs. I have a 09 G37s Coupe. I stripped the bolt at the bottom of the front passenger strut. The bolt that bolts around the stud that goes through the bottom of the strut and also through the bracket.
Does anyone one know what size this bolt is so I can get a replacement?
I am still trying to get the bolt off..going to try to use a dremel and cut off the bolt, last resort because I am running out of ideas and have destroyed the bolt.
Any advice will be greatly appreciated. Thanks
Old Nov 24, 2018 | 01:04 PM
PNW_IPL's Avatar
PNW_IPL
Irwin bolt extractor. Spray pb blaster let sit for an hour then use the bolt extractor. Happened to me about a month ago.
as for replacement buy a new endlink. The other bolt for the bracket take to a hardware store and compare threads.
Old Nov 24, 2018 | 01:56 PM
stealthee's Avatar
stealthee
Heat is your friend.
Old Nov 24, 2018 | 02:49 PM
slartibartfast's Avatar
slartibartfast
Yes. The Blue Wrench.
Old Nov 26, 2018 | 06:08 PM
VTREEZY's Avatar
VTREEZY
Thanks for the replies y’all. I went and tried the bolt extractor and stripped it more. The blue wrench was fun but I don’t think I used it effectively. Ended up using a dremel, hammer and chisel, and lot of patience to cut the bolt off.
Old Nov 26, 2018 | 06:14 PM
4doorfury's Avatar
4doorfury
When I had that issue I welded a socket to the nut and it came off much easier lol
Old Nov 26, 2018 | 11:30 PM
slartibartfast
Good work. At least you got a smidgeon of fun out of the ordeal. I'd be curious if you smack the front sway bar brackets like I do. My car isn't as low as yours.
MrJCole13
31
Sep 9, 2020 08:32 PM
OMG35S
32
Nov 23, 2015 11:41 PM
RedG37SNC
Aug 15, 2008 04:03 PM
