Lowering springs... just for the rear.
Old Sep 21, 2018 | 06:52 PM
giveherthatG's Avatar
giveherthatG
yes this is another lowering thread.
Before I ask, I just want to say this car is used as a DAILY DRIVER in TORONTO CANADA. So yes theres snow and lots of it.
So my issue is that I like how the front of my car is lower than the back. But I kind of want the back to be the exact the same height as the front. I don't want my car slammed, I want it at a decent height to get over the snow. Not become a snowplow. If you know what I mean. Is there a way to do this? All advice and suggestions welcome.
Old Sep 21, 2018 | 08:07 PM
Here's a similar thread but lowering just the front~
https://www.myg37.com/forums/g37-cou...the-front.html
Old Sep 23, 2018 | 12:06 PM
giveherthatG
I don't get the reasoning of lowering just the front. The back is higher the front...
Old Sep 23, 2018 | 05:38 PM
To give the car a raked look vs. lowering just the rear and have the front higher, raked look is more common.
Old Sep 23, 2018 | 10:39 PM
saywat?'s Avatar
saywat?
Naturally the front is higher than the rear
Old Sep 25, 2018 | 05:53 PM
giveherthatG
Yeah I took some time to really look at my car. O think I want all of it lowered. Thinking of getting BC Coilovers but i don't want to spend money on a camber kit. I'm not trying to slam my car, just to fill the wheel gap. Possible I can get away with it without any cons?
Old Sep 25, 2018 | 09:26 PM
I'd consider Tein Basis Z coilovers, these are a good choice for a mild drop (if you have a RWD). If you keep the drop under 1.5" you still should get the rear camber arm & toe bolt kit but the front should still wear ok without an adjustable arm.
Old Sep 25, 2018 | 11:14 PM
giveherthatG
Ah I have a 2011 g37xS coupe. Yeah def a mild drop only. What are my choices for coilovers, preferably ones with plastic or stainless steel threads. I live in Toronto, Canada so gotta deal with the winters
Old Sep 25, 2018 | 11:16 PM
giveherthatG
plus if I can save money without the need for both camber kits that would be cool. Lowering ur car is expensive 🙃
Old Sep 26, 2018 | 10:25 PM
In your case might stick with Swift lowering springs on your OEM shocks, this is a mild drop (good for your snowy winters) as long as your OEM shocks are in good shape. I would still recommend a rear camber/toe kit though.
Old Sep 26, 2018 | 10:41 PM
giveherthatG
I'm guessing after I put swift springs on, I'll have eventually have to get new struts and shocks? Hopefully thats further down the line. Good to know I only need the rear camber kit for now.
HotSawce
Feb 3, 2017 11:29 PM
Need 4 Speed
Brakes/Suspension
Jul 16, 2014 01:52 PM
love4boost
Mar 26, 2013 04:14 PM
Peyman
Oct 3, 2011 02:51 AM
importdps
Brakes/Suspension
57
Feb 10, 2010 10:16 PM
