rear rotor removal - need help ASAP!
Old Jun 18, 2018 | 09:26 AM
Landshark's Avatar
Landshark
AWD Auto ...
rear rotor is stuck ...
- parking brake released
- rear wheels up in the air on jackstands
rotor is actually free from hub (loose), but parking brake is holding it on and it won't budge ...
my problem is, the rotor won't turn for me to bring the little hole to 12 o'clock to loosen the parking brake via the little wheel. put car in Neutral, still will not turn.
help? should i just beat the snot out of it with a hammer? i don't want to damage anything, and the dust shield only gives me a small area behind the rotor to hit it anyway.
**** i know this isn't the correct forum, but i need to get this done soon and this forum is more active ...
Old Jun 18, 2018 | 09:51 AM
Surfnazi's Avatar
Surfnazi
Did you remove star screws in the hat
Old Jun 18, 2018 | 10:48 AM
JSolo's Avatar
JSolo
Just say no!!!!!
Put the wheel back on to use as additional leverage while rotating.
Old Jun 18, 2018 | 12:45 PM
FlashGuy's Avatar
FlashGuy
Give the side of the hat a few good whacks if you are no longer using the rotors.
My buddy says, "hit it like you've got a pair" hard.
Old Jun 18, 2018 | 01:21 PM
Landshark's Avatar
Landshark
yup! that's what i ended up doing and it worked.
the rotors were already loose from the hub - it was just the parking brake holding them on.
NCG37sC
Apr 17, 2018 11:14 AM
Infinite.G
Sep 28, 2017 06:38 PM
JohnnysG
99
Mar 22, 2011 10:09 PM
ironchef2008
Brakes
Mar 22, 2010 09:05 PM
J Ritt
Oct 29, 2007 05:41 PM
