Seeking help for strut replacement
Old May 28, 2018 | 04:31 PM
Xuan Wang's Avatar
Xuan Wang
Hi,
I own a 2010 G37X AWD couple. From this summer, the front passenger side strut starts making noises. An auto tech checked it out for me and the suggestion is to replace the strut assemblies on both sides.
I searched some economic replacement parts online and figure out there are lots of different models for G37 struts. From the descriptions, it's very hard to find the ones that exactly fit AWD couple.
I think AWD and RWD models should be different (from pictures, it seems that the AWD ones have extra mounting structures). But I do not know if the struts for AWD coupes and sedans are interchangeable.
Anyone has knowledge on this and can help me with it?
Thanks a lot.
Old May 29, 2018 | 02:56 PM
guy from norcal's Avatar
guy from norcal
Sounds like your mechanic is just guessing on whats wrong. Look at rockauto they make it super easy to find parts.
Old May 29, 2018 | 03:23 PM
Xuan Wang's Avatar
Xuan Wang
The website is very helpful. Thanks a lot!
Old May 29, 2018 | 07:36 PM
GdaddyNY's Avatar
GdaddyNY
I have an X sedan, and also want to replace my shocks/struts. I found the KYB website catalog very helpful. They valve the shocks differently for X coupe and X sedan. I called them as well. I’m going with the part numbers they gave me over the phone for X sedan
Old May 30, 2018 | 01:08 AM
slartibartfast's Avatar
slartibartfast
The coupe and sedan are interchangeable, so you could take this opportunity to increase damping rate a smidge with a coupe damper and get a sportier ride in you sedan.
And by the by, they are not struts, they're dampers. Moving this to the suspension forum.
Old May 30, 2018 | 06:44 AM
GdaddyNY's Avatar
GdaddyNY
Has anyone installed X coupe “dampers” in an X sedan?
KYB “dampers” are made stiffer/sportier to compensate for worn springs/suspension components. I am going to pair the X sedan “dampers” with Swift springs.
Old May 31, 2018 | 01:19 PM
PattyBoo81's Avatar
PattyBoo81
I actually just ordered Struts from KYB. I'm replacing my fronts & rears & pairing them with the Swift Springs as well. Here are the parts. These are for the 2015 Infiniti Q40 AWD:
(Qty)(1) Front Left Suspension Strut
Recommended OEM Replacement(Part Number) 340011
(Qty)(1) Front Right Suspension Strut
Recommended OEM Replacement(Part Number) 340010
(Qty)(2) Rear Shock Absorber
Recommended OEM Replacement(Part Number) 349089
Old May 31, 2018 | 01:54 PM
GdaddyNY's Avatar
GdaddyNY
Recommended OEM Replacement(Part Number) 340011(Qty)(1) Front Right Suspension Strut
Recommended OEM Replacement(Part Number) 340010(Qty)(2) Rear Shock Absorber
Same part #’s for 2011 G37X Sedan
Old May 31, 2018 | 02:25 PM
slartibartfast
And still not struts.
Old May 31, 2018 | 04:04 PM
GdaddyNY's Avatar
GdaddyNY
I understand, dampers. Tomato, Tom-A-to. Lol
KYB actually phrases them as shocks all around in their catalogue. Either way, you know what we’re getting at.
Oozki
Car Care & Detailing
May 7, 2018 05:30 PM
sharmelan
Jun 13, 2015 04:14 PM
Ryan@Forged
Brakes/Suspension
284
Nov 20, 2012 06:25 AM
jbrooks
May 13, 2012 03:32 PM
