G37X Rear caliper Bracket. Issue removing lower bolt
I'm talking about the two 19mm that hold the caliper bracket in place. Not the 14mm that hold the caliper to the bracket.
The top 19mm is easy to take off, however the bottom, I can't fit a socket there because there's a silver arm thingy there. It looks like a lower control arm? I tried using a 19mm wrench but I still can't get it to move even after dousing it for some time with a PB blaster.
Question is, can I remove the lower arm? is it hard? The bolts holding it in place look quite heavy duty and I don't have an impact wrench or any air gun to remove them if I could. Any ideas? I need to change the rear rotors.
Thanks all. God a long 19mm ratch wrench and it did the job wonderfully. Did both rear rotors yesterday and surprisingly enough they came out by hand without any issues. They were the original rotors too. The fronts were a pain to remove. Seems like my experience is almost backwards to everyone elses!
b2autodesigns
Wheel & Tires
507
Apr 5, 2018 11:38 AM
