how to hack replace a sway bar stud
Old Mar 7, 2018 | 07:39 PM
mwvolkma's Avatar
mwvolkma
Thought I would make a post on this as I couldn't find any when I looked. The stud that holds the sway bar to the subframe sheared itself off when I was loosening the nut. The only way I could think to fix this without taking apart many other things was to drill through it with a 10mm (or 3/8ths) drill bit and slide a 40mm long M10x1.25 bolt through the top of the subframe. You can then tighten the sway bar by holding a ratchet on the top bolt (tricky but not too bad).
mwvolkma
Mar 8, 2018 10:53 AM
ReplicaR
Jun 21, 2017 02:51 PM
mjnoles1
Dec 18, 2015 10:19 PM
Kevalteam
May 20, 2014 11:29 AM
Genseven
Aug 11, 2010 05:30 PM
