how to hack replace a sway bar stud
Old Mar 7, 2018 | 07:07 PM
mwvolkma's Avatar
mwvolkma
Thought I would make a post on this as I couldn't find any when I looked. The stud that holds the sway bar to the subframe sheared itself off when I was loosening the nut. The only way I could think to fix this without taking apart many other things was to drill through it with a 10mm (or 3/8ths) drill bit and slide a 40mm long M10x1.25 bolt through the top of the subframe. You can then tighten the sway bar by holding a ratchet on the top bolt (tricky but not too bad).
Old Mar 8, 2018 | 12:34 AM
justint5387's Avatar
justint5387
I think you could have punched out the stud and replaced it with a bolt.
Old Mar 8, 2018 | 05:59 AM
Baadnewsburr's Avatar
Baadnewsburr
I thought thats what he did, no?
Old Mar 8, 2018 | 10:53 AM
justint5387
He drilled through it
petemo94
Feb 14, 2022 08:13 AM
911turbo
Mar 30, 2018 12:16 PM
CAD
Feb 13, 2018 01:42 PM
zaz
Feb 6, 2018 01:02 PM
VQ37VHR13
Dec 29, 2017 08:41 PM
