Brakes & Suspension Reviews on brakes & suspension for G vehicles.
Review Z1 Subframe Bushing Collars
Old May 31, 2018 | 01:49 PM
  #91
bPChaos's Avatar
bPChaos
Damn. That's two unimpressed reviews, from two members who road track their cars.
You didn't feel any improved throttle response, like this guy here on the Z forum?
Z1 Subframe Bushing Insert/Collar Review - Nissan 370Z Forum
I wouldn't say I'm unimpressed - but it's an easy thing to forget that's there once you get used to it. At least, an easier thing to forget than the diff that used to flop around back there (did the diff bushings at the same time).
Like I've said before, on-off throttle response has improved. However, I try not to be too stabby on the throttle on the track, because smooth is fast. If you keep the car loaded, then you won't feel it as much because there's less of a transition. Additionally, my car is set up to be very soft in the rear - 8k springs with matched valving and stock swaybar - in conjunction with the taller sidewall and wider tire (tires are downsized to an 18inch; 275/40R18 all around), I've already lost a lot of the snappiness most people are probably used to feeling.
For the budget, if you're already in there taking care of a destroyed diff bushing and you want a bit more response, I don't see why you wouldn't do this. But as a standalone mod you would need a good chunk of a day to do if you're inexperienced, not so much.
Old Jun 1, 2018 | 06:09 AM
  #92
The Pope's Avatar
The Pope
Hashim..... have you installed your set yet? Look forward to your review on these or a review from anyone else that does not have coilovers or upgraded diff bushings, as I'd like to know what these collars will do with everything else in the rear stock.
Old Jun 4, 2018 | 01:49 AM
  #93
slartibartfast's Avatar
slartibartfast
Please read my review, again. Except for the trans mount, I was stock.
Maybe you're looking for another stock car review? Your post didn't make that clear.
Old Jun 4, 2018 | 06:30 AM
  #94
The Pope's Avatar
The Pope
I read your review (and thank you for it), but from your signature line, you have aftermarket diff bushings installed as well. Were the diff bushing installed prior to the collars? If so, that will change the evaluation of the collars. If the collars were installed first and you drove with them for a while before you upgraded the diff bushings, then your review of how the collars changed the suspension characteristics before the diff bushing upgrade would be what I'm looking for.
I'm wanting to hear from someone that still has the OEM diff bushings, as a review from someone that has only installed the collars is the only way to truly evaluate just the collars and that's why I keep asking Hashim if they have installed the collars that they have.
Old Jun 4, 2018 | 10:12 AM
  #95
Baadnewsburr's Avatar
Baadnewsburr
Unfortunately not yet, been busy travelling for work since last month and probably wont be home long enough to give it a shot till at least July... They're just sitting on my workbench in the garage
will do my best to post as soon as I do
Old Jun 4, 2018 | 04:51 PM
  #96
slartibartfast
Good point. I edited my initial post to indicate mods to the car at the time of the collar install.
wowwed
Sep 21, 2017 07:08 PM
4DRZ
12
Mar 12, 2017 10:48 PM
Kris 3.7
Oct 6, 2014 11:48 AM
GTSPEC-MARK
Oct 20, 2013 11:42 AM
