Anyone else have clearance problems with SPC camber arms?
Old Nov 5, 2017 | 10:11 PM
future62's Avatar
future62
With stock FUCAs I had no issues with suspension travel. Now with the SPC arms at the same front height (~26" FTG) I'm banging on big bumps. Really saps my confidence. I'm on Tein Basis Zs which are a hair soft so that doesn't help..... probably going to go back to stock arms as camber wasn't too bad but I wanted to know other people's experiences
Old Nov 6, 2017 | 01:16 PM
terribleone's Avatar
terribleone
I cannot personally speak to this (I have OEM camber arms) but I have heard about this being an issue with some other folks too.
Old Nov 6, 2017 | 03:11 PM
I was at 25.75" on B&G springs (prior to my current coilovers) and never had any clearance issues, but mine aren't the most current SPC part #.
Old Jan 19, 2018 | 10:58 AM
AARONHL's Avatar
AARONHL
Just bang out the metal part of the wheel well with a heavy hammer. If you remove the strut and end link you can move the hub up and down to see where the upper arm is hitting.
Old Jan 19, 2018 | 03:37 PM
slartibartfast's Avatar
slartibartfast
No strut, that's the damper.
Old Jan 19, 2018 | 04:20 PM
AARONHL's Avatar
AARONHL
yes strut...but technically you can just disconnect the upper control arm from the top of the hub so you have full movement to push it up and down to see where it hits. Then mark it with a sharpie and bang it out a little with a metal hammer. make sure you are precise
taking the strut out will give you a lot more room to swing da hamma
Old Jan 19, 2018 | 07:41 PM
saywat?'s Avatar
saywat?
its a common issue with lowered a certain lowness. it was a big topic on this forum years ago. read up. no fix. suggestion was to use g35 arms which helped but not complete fix
Old Jan 19, 2018 | 09:13 PM
Crazyirish's Avatar
Crazyirish
What Bart is saying (and is correct on) is that these cars don't have struts. It's a shock or damper. Struts are themselves structural members of the suspension.
Old Jan 19, 2018 | 09:20 PM
slartibartfast
Another option is to replace the SPC arms with SPL. They don't use that lock nut above the ball joint.
Old Jan 19, 2018 | 09:23 PM
Kpmikey808's Avatar
Kpmikey808
I posted this pic recently in a thread with tein basis coilvers
I have tein basis coilovers 26.25 FTG
front & rear spc control arms & camber kits
that lil Mark is where the top nut part of control arm is hitting that metal - it sounds bad in the car when yr driving & it hits -
Took those pics when car was on lift for rear tires
front right & left side had them
there’s no damage to control arm - just that lil mark & that loud thud sound lol
happens more when I have whole family of 5 in the car & going fast over a small bump or weird part of road
my other buddy say they hammer a little like other guy said or they cut that part out
Old Jan 19, 2018 | 09:28 PM
Kpmikey808's Avatar
Kpmikey808
Slartibartfast I noticed some members tags spc rear & spl front controls
Maybe the hammer part would work??
Once I saw there was minimal damage & got use to that loud knock here & there
It has grown on me
But that first loud knock I heard scared me lol
Old Jan 20, 2018 | 01:30 PM
future62's Avatar
future62
The issue isn't the nut above the ball joint.... the ball joint on the adjustable kits is a lot taller than the OEM one. I am into the suggestion of the V35 OEM arm. I think my SPC arms are maxxed out for negative camber and are only at -2.2 or so. If the stock V35 arms are a little shorter and fit properly they'd be perfect.
Old Jan 21, 2018 | 10:46 AM
AARONHL's Avatar
AARONHL
https://en.wikipedia.org/wiki/MacPherson_strut
Old Jan 23, 2018 | 09:31 AM
Crazyirish's Avatar
Crazyirish
Our cars don't have a McPherson Strut based front suspension. Which is why we have to use adjustable front upper control arms to adjust the camber. If we had a McPherson strut setup we would merely need adjustable upper strut mounts.
https://en.wikipedia.org/wiki/Double...one_suspension
Old Jan 23, 2018 | 10:08 AM
AARONHL's Avatar
AARONHL
I understand the difference but why correct me on the strut everyone knew what I meant........
