looking for single person brake bleed kit
Old Oct 23, 2017 | 08:25 PM
nethole's Avatar
nethole
Anyone found parts that can do the job for a G37 reliably? (such a pressurized container so a single person can bleed the brakes)? -- please post links
Old Oct 23, 2017 | 09:47 PM
bPChaos's Avatar
bPChaos
I use the Motive Power bleeder. Get the Ford cap (0107 or 0117) for our cars.
https://www.summitracing.com/parts/mvp-0117
I believe the only difference between the two is that the 0117 comes with a nicer aluminum cap instead of a plastic one. It's the one I got.
Old Oct 23, 2017 | 09:59 PM
micafd3s's Avatar
micafd3s
ive used speed bleeders....
Old Oct 23, 2017 | 10:19 PM
stealthee's Avatar
stealthee
You don't even need a pressurized container. You can simply get some tube that fits tightly over the bleeder and run it into a container full of fluid.
This is the first video I found in a Google search
Old Oct 24, 2017 | 12:27 AM
Victory's Avatar
Victory
I have a motive and it makes things easy, but it's expensive for what it is. If i had to do it again id make my own from a $10 garden sprayer like i did for my ATF change project
Old Oct 24, 2017 | 05:43 PM
Surfnazi's Avatar
Surfnazi
Or do the turkey baster method. Suction out as much then fill with new fluid then repeat in a week. 3-4 drains will do the job
Old Oct 24, 2017 | 05:44 PM
nethole's Avatar
nethole
turkey baster has no value for nipples on calipers . . .
Old Oct 24, 2017 | 07:39 PM
slartibartfast's Avatar
slartibartfast
Turkey baster won't dislodge air bubbles. Power bleeder also gets the job done in one session.
Old Oct 25, 2017 | 02:18 AM
UCLAG37's Avatar
UCLAG37
Here's a thread on brake bleeders and brakes. If you get the Motive and want to keep it for a while, I strongly suggest buying the aluminum cap. The Motive was a breeze to use.
https://www.myg37.com/forums/brakes-...questions.html
UCLAg37
Old Oct 25, 2017 | 05:25 AM
Surfnazi's Avatar
Surfnazi
U suction out of the master cylinder where you add brake fluid
Old Nov 3, 2017 | 09:07 PM
RadioFlyer's Avatar
RadioFlyer
Speed Bleeders work fine for me.
Old Jan 30, 2018 | 01:24 PM
Surfnazi's Avatar
Surfnazi
Get large syringe and suction fluid out of master cylinder. Refills drive a week and redrain/refill again. A couple of times and you have gotten most of the old fluid out. Dealer uses tool to engage abs system to get fluid stored in there
Old Jan 30, 2018 | 03:58 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Been using the motive power bleeder for the last 6 years. Works well, no monkeying around, do it once and done with for the next 2 years.
Old Jan 30, 2018 | 04:21 PM
Lego_Maniac's Avatar
Lego_Maniac
+1
I've had mine for over a decade. Love it.
I'm going to upgrade from the plastic 'Ford' adapter to the aluminum one.
Old Jan 30, 2018 | 06:11 PM
JSolo's Avatar
JSolo
Just say no!!!!!
^^Is there something wrong with the plastic cap?
