Two-piece Rotor discussion
Old Jun 8, 2017 | 05:16 PM
  #46
Never heard of RacingBrake. Hmm. $633/pair and no blanks.
Two-piece rotor (Slot) - 350Z FRONT 06-09, G35 FRONT 05-08
Old Jun 8, 2017 | 05:33 PM
  #47
2GoRNot2G's Avatar
2GoRNot2G
They have been in business since 1985, so they are not new. They simply focus on racing applications mainly for track cars, so unless you frequently attend track days you probably wouldn't hear their name pop up very often. In addition to rotors they also make some VERY sweet calipers which Brembo even copied some of their features from.
But like I said they are very proud of their products and their pricing reflects that. They do, however, have some patented technology that goes into their rotors like their "open slots", and they do use similar materials, manufacturing processed and the same heat treating as used to make Formula 1 rotors. Although I doubt any of this is really that important for a street car.
Disc Surface Finish - RacingBrake.com
Feature Comparison - RacingBrake.com
Racing pad selection and brake pad deposit - RacingBrake.com
Old Jun 8, 2017 | 05:34 PM
  #48
p0on's Avatar
p0on
I went in on the full set of Z1 2pc F&R Rotors, the Z1 "premium" SS brake lines, EBC Yellows, and Motul RBF600 (time's up for new fluid, so why not?).
Have yet to swap them all in yet, but 100% agree with everything on this thread and more. Can't wait.
Old Jun 8, 2017 | 05:36 PM
  #49
2GoRNot2G's Avatar
2GoRNot2G
By blanks do you mean solid discs (i.e. not drilling) or just 1-pc rotors? Because they do make 1 piece rotors, but not with a solid disc.
Old Jun 8, 2017 | 06:49 PM
  #50
I mean no slots, no drill holes. Two-piece blanks. Maybe I'm misappropriating the word "blanks". IDK.
Here's the rationale for blanks: my Vossens have an obvious directional spoke design. With that in mind, I'd like to avoid adding yet another swept-back (or swept-forward) eye-line to the wheels. Know what I mean? That's why I was interested in the "sprinkle slot" (stupid name) that Z1 has.
But after talking about it here, it bubbled up that I needn't bother upgrading the rear rotors. So if I'm going to have OEM blanks in the rear, then I should match that with non-slotted, not-drilled (but two-piece) rotors up front.
That's my thinking for now. But it's new, and subject to change, LOL.
Here's yet another pic of my car. I don't think a sweeping design for slots or drills would look good behind Vossen CVT's.
However, R1cky's gold calipers sure would look nice. Particularly with the INFINITI decals in black like this.
Originally Posted by R1cky
Another great thread you've started here, John!
That was nice of you to say. Thanks!
Old Jun 8, 2017 | 11:24 PM
  #51
antirice's Avatar
antirice
I don't believe those are for our stock BBK. RacingBrake 2-piece rotors are $$$$. I remember they are close to $1000/pair for the front.
Old Jun 9, 2017 | 07:15 AM
  #52
Lego_Maniac's Avatar
Lego_Maniac
$2,065.39 to be exact excluding shipping.
I'd be curious to know where all these 2-piece rotors are made. OEM rotors are made in Japan. I might have a hard time dropping this much coin on something made by a 14 year old girl in a dimly lit foundry in China.
Old Jun 9, 2017 | 07:27 AM
  #53
You're right, that was the non-sport rotor. The sport rotor for the front costs $1,150 for the pair.
Two-piece rotor (Open Slot) - 370Z (Sport) FRONT 2009
That's nuts. Could be the most awesome rotor in all creation, but nothing that I can justify for my sedan.
Old Jun 9, 2017 | 08:08 AM
  #54
ryanwhite74115's Avatar
ryanwhite74115
Two-piece Rotor discussion-photo912.jpgTwo-piece Rotor discussion-photo811.jpgTwo-piece Rotor discussion-photo962.jpgTwo-piece Rotor discussion-photo775.jpg
Saved about 700 compared to z1 package but I'm liking my new setup. Hawk HPS 5.0's and DBA 4000 T3's all around. Oem weights though...
Old Jun 9, 2017 | 08:46 AM
  #55
Not a two-piece, Ryan. But I like the cross-slotted pattern.
Any comments about the HPS pads?
Old Jun 9, 2017 | 01:15 PM
  #56
ryanwhite74115
Thumbs up
HPS pad...I've been using it for 24 hours so take it with a grain of salt. Not near as much bite in the beginning, but the rate of braking is extremely linear. The OEM pad was like...like a cottonmouth snake...One big *** bite and then it chokes. The HPS pad is more like an alligator, slow and steady in digestion of the pad. That probably doesn't make any sense but it does in my head
Noise is non-existent. Dust seems .... on parity with OEM pads I think, maybe 10% worse. NO MORE!
For me I'm slightly disappointed I have to press the brake further, but it is nice how reliably easy it is to use now. I think my brain just has to adapt to how this pad operates.
...................................OEM............ ....Hawk HPS
Breathing on pedal.........Mild.................Nothing
Mild Pressure.................Moderate.........Mild
Moderate Pre.................Maxed out........Moderate
Extreme Pre..................Moderate..........Extreme braking
Does this make sense? The OEM pad drops off significantly after several hard stops (think Tail of the Dragon area in NC) whereas the Hawk is just extremely linear.
Old Jun 9, 2017 | 01:45 PM
  #57
"linear". That works for me.
Old Jun 9, 2017 | 02:08 PM
  #58
What's the bed-in process as per Hawks' recommendation for the 5.0 pads Ryan?
Old Jun 9, 2017 | 02:18 PM
  #59
Lego_Maniac
Ryan, did you bleed your brakes when you swapped rotors and pads?
Old Jun 9, 2017 | 02:28 PM
  #60
ryanwhite74115
Per Hawk:
1. After installation, 6-10 stops from 30-35 applying moderate pressure
2. 2-3 stops from 40-45 applying hard pressure
3. DO NOT DRAG BRAKES
4. Allow 15 minutes for cool down
5. Brakes are ready for use
I have two bottles of Motul 600 but did not use them. I thought about bleeding the brakes but said to myself, why? I didn't remove any fluid from the calipers. I am open to suggestion as to why I should though. Additionally, I had the fluid changed only 12000 miles ago.
