Loose upper control arm spc kit question
Old May 9, 2017 | 09:24 PM
DJMAC's Avatar
DJMAC
Hello,
I cant figure this out, i tighten the top nut on the upper control arm and after 15 min it comes loose again. Nissan torque to spec 130 lb i think and still came loose... does something seem wrong with pic ?? What am i missing here ....
Old May 9, 2017 | 10:02 PM
Bommerang's Avatar
Bommerang
Thats odd, just installed mine yesterday and used a GIANT 27mm spanner and a strong friend to tighten it down like crazy and hasn't given me any issues thus far. Are you sure it isn't cross threaded, rounded off or anything? Not sure if adding Loctite would be good or not.
Old May 10, 2017 | 09:30 AM
jfisher's Avatar
jfisher
Use some red locktite?
Old May 10, 2017 | 11:15 AM
DJMAC's Avatar
DJMAC
Well I took it out for a test last night and again today and it has held. I wasn't able to get my torque bar in there so just used a giant wrench and tightened until It squeaked.
I can only assume Nissan did not even try to tighten it.
Old May 10, 2017 | 08:37 PM
Bommerang's Avatar
Bommerang
Sometimes a giant wrench can get the job done !
Old May 11, 2017 | 05:17 AM
Surfnazi's Avatar
Surfnazi
Wonder if the threads got stretched on the bolt
Old May 11, 2017 | 07:50 PM
saywat?'s Avatar
saywat?
if the thread squeaks doesnts that usually mean ur over tightening"?
Old May 13, 2017 | 08:25 AM
Ape Factory's Avatar
Ape Factory
Download the factory service manual for the front suspension (FSU). The torque rating is 41 ft. lbs. You've now probably screwed up the SPC spindle that slides in there.
I don't mean to be harsh, but if you're working on your car, you need to look this sh*t up. If you screw something up on your suspension, you could have a catastrophic failure at speed and kill yourself or someone driving around you. I prefer you alive to being dead. Just saying
Here's a direct link to all the FSM's: Infiniti G35 / G37 Factory Service Manuals - NICOclub
Not sure what year you have but once in there, you'll want the one labeled FSU (front suspension unit).
Old May 13, 2017 | 10:41 AM
DJMAC's Avatar
DJMAC
Ape Factory I totally hear you, trust me.
I let Nissan do most of my work as I'm no mechanic. That was the problem I got it back and it came loose. so I had to tighten it up in the meantime so I wasn't stranded.
SPC spec say the following:
to adjust camber, loosen the adjusting nut and move the adjustable ball joint in or out in the control arm slot to obtain the desired
camber reading then torque the adjusting nut to 120 lb-ft. (162nm)
I dropped off the SPC instructions with them so I'm only assuming they tightened it to the FSM specs ?! Hoping to get it back today. I just wondered if anyone else had issues with the control arm coming loose.
thanks
