Coilovers for AWD coupe
Old Apr 20, 2017 | 08:46 PM
aBlackG's Avatar
aBlackG
You don't even have to disconnect both ends of a bar. Disconnecting one will do the trick unless the free end bumps against something that interferes with getting the other hub into the position you want.
I can see this work as well!
Old Apr 21, 2017 | 03:58 PM
slartibartfast's Avatar
slartibartfast
Originally Posted by aBlackG
Thanks! Even though the front total toe and as well as individual toes are in the range that's described on the sheet (-0.08 - 0.25 deg for total toe & -0.04 - 0.13 deg for individual)? Or is that not how you read it?
It may be within spec but you have more negative camber than spec and that will exacerbate toe wear on the inside shoulder. Ask for zero toe if they can do it though you will have to ride heard on the steering wheel more than you may want.
Old Mar 15, 2019 | 11:55 AM
Vq37XS's Avatar
Vq37XS
2 years later but id like to point out that he did the alignment based on a sedan and not a coupe! just looking at old pots since im going to pull the trigger on some coils for my X as well!
Old Mar 15, 2019 | 02:47 PM
slartibartfast
Coupe and sedan alignments are interchangeable. As long as you minimize toe, camber won't significantly wear your tires.
Old May 2, 2021 | 04:03 PM
Idan Zem's Avatar
Idan Zem
What did you end to getting for ur coupe x?
That’s dope what did you end up getting
