Help! Bbk upgrade from non sport
Installing the rear akebono caliper and I've come to a road block. The point where the line is screwed onto the caliper is what I'm talking about. The bolt doesn't seem to screw in all the way so the line has space to wiggle and potentially leak fluid. Should I just add washers to remedy this?
You probably need the shortened banjo bolts if you're using your stock lines. https://www.z1motorsports.com/brakes...lt-p-8488.html
if those are stock lines you need shorter banjo bolts
mingc08
Oct 18, 2016 11:25 AM
bsanalyst
Sep 30, 2016 05:50 PM
