Best lubricant for control arm ball joint
Sep 2, 2016 | 02:58 PM
for upper control arm ball joint, what is the best spray based lubricant? Lithium based or silicone based? taking into affect the spray has to be rubber safe.
Sep 6, 2016 | 06:11 AM
Oem control arm? If so lithium
Sep 7, 2016 | 02:32 PM
Quote:
Originally Posted by
Surfnazi
No, after market. Kinetix to be exact.
Sep 7, 2016 | 02:57 PM
Don't use white lithium grease as it will degrade rubber. Just use a silicon based lube.
Sep 16, 2016 | 05:59 AM
Silicone will grab dirt wearing it down faster you can also use anti seize
Sep 16, 2016 | 08:17 AM
According to Kinetix, their ball joints (actually heim joints) are teflon lined. If they need lubrication, it means they should be replaced.
Sep 25, 2016 | 10:35 AM
Crazyirish
Hmmn. I asked Kinetix directly myself and they said they use marine white lithium grease.
Sep 25, 2016 | 02:39 PM
celwin
Not surprised. Doesn't change the fact that teflon lined rod ends shouldn't need lubrication.
PNW_IPL
Jan 20, 2022 10:58 AM
zacheller
Nov 1, 2016 11:34 PM
Jesus-G37Sedan
Aug 22, 2016 09:44 PM
PaulieP
Aug 11, 2016 07:16 AM
ajaffer
Aug 8, 2016 10:28 AM
