Brakes & Suspension Reviews on brakes & suspension for G vehicles.
Review Z1 Motorsports Brake Master Cylinder Brace
Old Dec 5, 2016 | 09:44 AM
zer099's Avatar
zer099
I grabbed a few pictures as well:
Not much to look at.
Old Dec 6, 2016 | 09:06 PM
2GoRNot2G's Avatar
2GoRNot2G
Eek! That's one dirty engine bay. But thanks for posting the pics... That help a lot!
Old Apr 13, 2017 | 05:00 PM
slartibartfast's Avatar
slartibartfast
Need to find a teenage girl who knows how to use tools. Orange unicorn?
Old Apr 24, 2017 | 10:58 PM
jpowersjr2's Avatar
jpowersjr2
So worth it, not worth it?
Old Apr 25, 2017 | 12:28 AM
PNW_IPL's Avatar
PNW_IPL
Second that.
Old Apr 25, 2017 | 09:46 AM
zer099's Avatar
zer099
For the price it does it's job perfectly. I would be hard pressed to say everyone would know/feel the difference between firewall flex and just soft brakes. But it's something someone that does have the knowledge/feel would notice. If you track your car I recommend it to get you a uniform/linear pedal feel.
Old Apr 25, 2017 | 10:32 AM
Lego_Maniac's Avatar
Lego_Maniac
I'll second "worth it"
Old Apr 25, 2017 | 12:04 PM
PNW_IPL's Avatar
PNW_IPL
Perfect response zero!
Thanks Lego!
Old Apr 25, 2017 | 02:45 PM
Baadnewsburr's Avatar
Baadnewsburr
I sure hope it is worth it. I have it at home in a box waiting to be installed...I'll try to post some pics of the install
Old Apr 25, 2017 | 02:50 PM
jpowersjr2's Avatar
jpowersjr2
Let us know how the install goes Hashim!
Old Apr 28, 2017 | 06:49 AM
The Pope's Avatar
The Pope
Me to. Hopefully I'll get it installed sometime over the next two weeks.
I've picked up some "Retaining Washers" or "Push Nut" from a local hardware store and I'm going to see if that will help with the mounting screws. By using these washers I can put the two M6 screws through the bracket and then press on the washer from the opposite side. They will keep the screws from falling out as I position the bracket. I'm going to just install the washers just far enougn onto the screws so that they will retain them to start with. once I have both screws started into the nuts within the inner fender, the washers will be pushed all of the way to the bracked as I tighten the screws down. Well.... that's my plan. I'll attach a photo of the type of washer I'm planning to use to help anyone who isn't sure of what I'm talking about.
Attached Thumbnails Z1 Motorsports Brake Master Cylinder Brace-china-push-nut-bearing-clip-retainer-washer.jpg
Old Apr 28, 2017 | 06:53 AM
Mattlorentzoe's Avatar
Mattlorentzoe
Looking forward to some more pictures or a video! I need to install mine also
I've picked up some "Retaining Washers" from a local hardware store and I'm going to see if that will help with the mounting screws. By using these washers I can put the two M6 screws through the bracket and then press on the washer from the opposite side. They will keep the screws from falling out as I position the bracket. I'm going to just install the washers just far enougn onto the screws so that they will retain them to start with. once I have both screws started into the nuts within the inner fender, the washers will be pushed all of the way to the bracked as I tighten the screws down. Well.... that's my plan. I'll attach a photo of the type of washer I'm planning to use to help anyone who isn't sure of what I'm talking about.
Old Apr 28, 2017 | 07:11 AM
Lego_Maniac
I used a small amount of blue painters tape to hold the nut onto the driver.
Make sure it's assembled correctly before you install it. Mine was orientated backwards....which I didn't realize until AFTER I mounted it
Take before and after photos of your knuckles
Old Apr 28, 2017 | 07:41 AM
  #29
Baadnewsburr
if I take a video I'm recording the swearing too
Old May 29, 2017 | 05:22 PM
  #30
Baadnewsburr
I was about to do it last Saturday and I actually looked at the clearance on these things, holy crap, no way my fat mits are gonna fit in there ... theres really almost no room to even get the bracket in there let alone tools, fingers and the screws...i'll try again in the coming weeks when I have more time
