Sway Bar Hitting Lower Control Arm
Old Aug 18, 2016 | 04:57 PM
zacheller's Avatar
zacheller
My 2010 g37s anniversary edition was lowered with Eibach Pro-Kit lowering springs, and Stillen sway bars back in 2010. About a month later the car started making a popping/rattling noise on the drivers side every time I would go over the slightest bump in the road. It is getting so annoying and we finally took it to get it fixed. With the car in the air it was clear that the front Stillen sway bar was hitting my lower control arm and grinding it down. Anyone ever have this issue? Know how to fix it? Also I get a squeak sometimes as well. One guy that looked at it said it's the upper strut mount... The other guy said my sway bar bushings could be the blame. Thoughts?
Attached Thumbnails Sway Bar Hitting Lower Control Arm-img_1766.jpg   Sway Bar Hitting Lower Control Arm-img_1765.jpg   Sway Bar Hitting Lower Control Arm-img_1759.jpg   Sway Bar Hitting Lower Control Arm-img_1758.jpg   Sway Bar Hitting Lower Control Arm-dsc_0344.jpg
Old Aug 18, 2016 | 06:32 PM
Kris9884's Avatar
Kris9884
If there isn't a less intrusive option, I would just sand/grind those corners down to a rounded edge and be done.
Old Aug 18, 2016 | 09:51 PM
PNW_IPL's Avatar
PNW_IPL
Damn that blows wonder if any other folks have this issue
Old Aug 19, 2016 | 11:48 AM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
I'm wondering if that was the correct part for the coupe. I think Stillen might have a different part number for the Sedan, Coupe X etc
Old Aug 19, 2016 | 02:33 PM
zacheller's Avatar
zacheller
I mentioned that to the guy at Stillen and he said that would weaken the bar and that it definitely should not be hitting.
Old Aug 19, 2016 | 02:36 PM
zacheller's Avatar
zacheller
I'm gonna ask Stillen if they sent us the wrong one by mistake... The stock sway bar is cut on the edges at a 45 degree angle which makes me wonder if they sent me the wrong thing.
Old Aug 19, 2016 | 06:48 PM
Kris9884's Avatar
Kris9884
Meh, he's covering his butt, it would have no ill effect rounding off the edge to keep it from rubbing. Promise.
That being said, I'm sure the right size bar wouldn't be rubbing to begin with, I bet you have the wrong one.
Old Aug 19, 2016 | 09:31 PM
zacheller's Avatar
zacheller
I might have to just round it off. The stock sway bar is rounded off... They might have sent me the wrong thing. The problem is, this was back in 2010 and I'm just now getting all this stuff figured out. That was stupid on my part to wait this long. Hopefully Stillen can take care of me.
Old Aug 19, 2016 | 10:25 PM
PNW_IPL's Avatar
PNW_IPL
6 years you knew of the problem
Old Aug 29, 2016 | 10:44 PM
350zspeed's Avatar
350zspeed
lmfao
Old Nov 1, 2016 | 11:31 PM
zacheller's Avatar
zacheller
I finally got it fixed!! The squeak was simply that the sway bar bushings needed grease. The popping noises/rattle I was experiencing was due to both my upper control arms being loose. I took it by a local shop beside my school (Liberty University) in lynchburg VA and they fixed me up in a few hours. All noises completely gone and it drives better for about 100 bucks.
The sway bar was very rarely hitting (not causing the constant rattle) however I installed the stock sway bar and Im sending this one in for a new one under warranty.
Old Nov 1, 2016 | 11:34 PM
PNW_IPL's Avatar
PNW_IPL
okay.
LOL
G37sGraphite
Feb 23, 2017 07:37 PM
xstarpro
Apr 1, 2016 01:05 PM
armino41
Mar 30, 2016 01:25 PM
Strongblood8
Mar 25, 2016 06:45 AM
bonstubon
Mar 18, 2016 04:29 PM
