Brake Upgrade
Old Apr 22, 2016 | 06:43 PM
Marionan's Avatar
Marionan
Brake Upgrade
Whats up guys,
I was looking to upgrade my brakes from the stock non-sport X brakes, except I'm on a somewhat tight budget. I was wondering if its possible to get the Akebono calipers and bigger rotors for the front, and just take the stock 2 pot brakes currently on the car and move them to the back? I feel like this would offer a decent upgrade in stopping power without being too expensive. Thoughts?
Old Apr 22, 2016 | 07:01 PM
slartibartfast's Avatar
slartibartfast
I seriously doubt this is viable without adding an additional proportioning valve assuming the bolt pattern is identical and the caliper mount places the caliper in the same position side-to-side. Are the front and rear discs even the same diameter?
Old Apr 22, 2016 | 09:03 PM
SonicVQ's Avatar
SonicVQ
If you are on a tight budget and want better stopping power, get better pads.
As far as I know, there is no way to fit the front calipers on the rear rotors.
Old Apr 22, 2016 | 10:02 PM
You'll spend much more trying to retrofit those calipers and then you"ll still have a funky hybrid setup that might make your car hard to resell. Just put money aside and keep your eyes out for a used set of Akebono calipers on ebay or check wrecking yards. Here's a thread on getting the most bang for your buck to source them new.
https://www.myg37.com/forums/brakes-...the-cheap.html
Old Apr 23, 2016 | 06:25 PM
Kris9884's Avatar
Kris9884
Yeah what he said ^^^.. Grab some pads, then rotors, then stainless lines, in that order.. Should've gotten the S model bud.
Old Apr 23, 2016 | 06:38 PM
VenomGT9's Avatar
VenomGT9
https://orlando.craigslist.org/pts/5476666385.html
See what this guy will let them go for
Old Apr 23, 2016 | 08:31 PM
G37xhibeet's Avatar
G37xhibeet
https://miami.craigslist.org/brw/pts/5549543420.html
Old Apr 24, 2016 | 12:50 AM
Marionan's Avatar
Marionan
Thanks for the help guys, I can get a pair of front calipers for about $400, so for now I think I'll just get the fronts with some new rotors and pads, and do a pad and rotor upgrade for the rear
Goonz
19
May 28, 2024 03:41 AM
4DRZ
Motorsports / Track
17
Jun 17, 2016 03:03 PM
m3clubracer
Apr 20, 2016 09:14 PM
Brandon HoDoan
Buying & Leasing
Apr 17, 2016 07:57 AM
