Brakes & Suspension Reviews on brakes & suspension for G vehicles.
Review Tein Basis coilovers on '13 G37S sedan 6spd
Old Nov 21, 2015 | 01:13 PM
lobuzz311's Avatar
lobuzz311
Originally Posted by 4DRZ
That's a really bad idea! We had someone try that in auto shop class in high school and the spring was under such load that it shot right through the garage door. If someone was standing there, they would have been toast! Fortunately I have access to a shop so I will always use a spring compressor.
I figured I'd get grief over that... Lol
I have a spring compressor at home. It just isn't necessary for these struts. It literally popped an inch once it let go. It wasn't flying anywhere. And it took 1/10th the time.
But, as always, do whatever you're comfortable with...
Old Nov 22, 2015 | 05:58 PM
jfisher's Avatar
jfisher
I must be reading your post wrong. You say they don't make these for the AWD cars, but you installed them anyway on your AWD sedan?
You do need the top hats for the coilovers as they do not come with top hats. I know the springs are different on the AWD, but you definitely need a spring compressor for the G37S in the front.
I have D2's. My D2's have their own top hats so that's where the confusion was. I was just referring to my own install experience. My bad. Didn't know they were different.
Old Nov 23, 2015 | 11:59 AM
4DRZ's Avatar
4DRZ
I hear you. I just didn't want some kid who doesn't know any better to read your post and take his head off. Because I saw a spring fly through a door using your trick, I have always used a spring compressor. It does not take much compression to equal a lot of force.
Oh yeah, most coilovers will have their own top hat. That makes sense now if you have different coilovers. You made it sound like you had the Tein Basis.
Old Nov 27, 2015 | 05:08 PM
RJ's_G37's Avatar
RJ's_G37
Just wanted to thank you guys..been itching at getting coils for a while and i have been reading your guys input and decided to buy these tein basis for a hell of a deal at zspeed..thanks again guys
Old Nov 27, 2015 | 06:13 PM
4DRZ's Avatar
4DRZ
I saw they have a good deal on them for Black Friday similar to when I got them. I think you will like them. Let us know when you have questions.
Old Nov 27, 2015 | 10:54 PM
RJ's_G37's Avatar
RJ's_G37
I will hopefully when they come me and a buddy can get them on..thanks
Old Nov 28, 2015 | 12:07 PM
4DRZ's Avatar
4DRZ
If you have the right tools and have done a suspension before, the Tein Basis are a breeze to install. Probably the easiest suspension I have ever done. I was pleasantly surprised.
Old Nov 28, 2015 | 12:34 PM
lobuzz311's Avatar
lobuzz311
Yeah, the install is really straight forward.
The only doozie was the one large nut (19mm, I think?) on the front suspension bracket. Needed a 24" long 1/2" breaker bar with my jack handle as a 4 foot cheater bar. It just didn't want to give.
I've gone back a few times to change the suspension around since and it was never as hard as that first time, even when properly torqued down. You might want to PB Blaster the f*** out of it the night before...
Old Nov 28, 2015 | 12:41 PM
4DRZ's Avatar
4DRZ
Did you have air tools? I used PB Blaster on everything right before I started and everything came loose ok.
Old Nov 28, 2015 | 05:43 PM
lobuzz311's Avatar
lobuzz311
Not at the time. I do now. But since most people don't, I thought it was worth mentioning. Also, it was a CA car with 25k miles, so it's not like it was corroded.
Old Nov 28, 2015 | 08:50 PM
RJ's_G37's Avatar
RJ's_G37
yeah we did my swift install and it was a PITA for the large nut to come off..hes done coilovers before so hopefully this coming week or week after they are on
Old Nov 29, 2015 | 11:19 AM
Did you use a backer wrench on the nut behind that 19mm bolt? I forget what size it was, I used an SAE size that was close IIRC and w/ the nut backed up it popped free easy w/ a 2 ft breaker bar (w/ PB Blast sprayed on the night before.)
Old Nov 30, 2015 | 11:33 AM
4DRZ's Avatar
4DRZ
Gotcha. I imagine that could suck without air tools
Old Dec 4, 2015 | 05:37 PM
  #29
RJ's_G37's Avatar
RJ's_G37
mine came in yesterday. will try to install tomorrow..
Old Apr 6, 2016 | 01:36 PM
  #30
4DRZ's Avatar
4DRZ
UPDATE: Raised the front and rear about 1/4" which compressed the spring and they ride noticeably better over "bouncy" roads.
