Damn strut bolt
Old Jul 27, 2015 | 10:50 PM
astat4's Avatar
astat4
Damn strut bolt
So for some reason this mf will not come loose. Why are they so tight!!!! I was only able to put 1 from spring cause I ran into this problem.
What are my option's? And where can I buy this nut/bolt
Old Jul 27, 2015 | 11:32 PM
micafd3s's Avatar
micafd3s
dang... have never seen a bolt stripped like that before...
you can grab that bolt from any parts store..
soak it in pb blaster... torch it and perhaps you can use vice grips on it..
otherwise.. cutting the thing and just replace the nut and bolt together..
Old Jul 27, 2015 | 11:37 PM
jroyalty7's Avatar
jroyalty7
Ohhh yeah I was just reliving this memory when I put up my build.thread last night. I had the exact same problem, tried everything basically torching and cutting it is how it came off. I was able to grab the replacement bolt from my local pepboys.
Old Jul 27, 2015 | 11:58 PM
AroundTheG37's Avatar
AroundTheG37
Are you guys using 12 point sockets because mine came out pretty easy with a 6 pointer.
Old Jul 28, 2015 | 12:13 AM
jroyalty7's Avatar
jroyalty7
I had a 6 point impact socket on impact gun, still wouldnt budge... Although it was 10 degrees out also so Im sure that didnt help
Old Jul 28, 2015 | 12:59 AM
Jonesmeister11's Avatar
Jonesmeister11
10 degrees... C? Where are you located???
Old Jul 28, 2015 | 02:04 AM
Epiphany's Avatar
Epiphany
Come north of the border and you'll start to find places not a lot warmer than that during the day, and even cooler at night.
Old Jul 28, 2015 | 06:54 AM
astat4's Avatar
astat4
I tied everything.. the fact that I don't have a good leverage causes it to slept when pulling up on the wrench. So it would slip.
Tried impact gun, kicking it, pb blaster, wd40, nothing lol
Old Jul 28, 2015 | 07:34 AM
quakerroatmeal's Avatar
quakerroatmeal
Are you holding the bolt from the other end at the same time as well?
Old Jul 28, 2015 | 07:48 AM
jroyalty7's Avatar
jroyalty7
Lol, good ol Buffalo, NY where this past February we didn't break above freezing the entire month and most days Antarctica was warmer
Old Jul 28, 2015 | 07:53 AM
astat4's Avatar
astat4
Yeah I had a wrench on the other side.
Old Jul 28, 2015 | 07:57 AM
You need a damaged nut remover. And torque.
ck1109
Oct 15, 2015 11:06 PM
faze2988
Oct 7, 2015 12:05 AM
si_driver
Sep 30, 2015 11:46 AM
BurtoN86
Sep 30, 2015 03:32 AM
dedmanchan
Sep 24, 2015 11:25 PM
