camber kits... Godspeed?
Old Apr 24, 2015 | 03:41 AM
buggzg37s's Avatar
buggzg37s
What's up every one. So I know there are tons of treads about camber kits but my specific question is ****has anyone used the GODSPEED camber kits and what's your take on it.****** I'm planning on lower my G on TEIN H-Techs. Just looking for a smooth drop to close up the gap in the wheel well a bit.
Thanks for the input.
Old Apr 24, 2015 | 08:49 AM
Bravo at's Avatar
Bravo at
Look up this G in the garage section: https://www.myg37.com/forums/garage/...nguyening.html
He has them listed as one of his mods.
Old Apr 24, 2015 | 09:10 AM
I think for the $50 difference in price (at least for the rear arms, IDK if they make a front arm) I'd just go w/ SPC/Eibach parts.
Old Apr 24, 2015 | 09:23 AM
ANMVQ's Avatar
ANMVQ
IMO I wouldn't buy anything from them.I bought wheel lugs and never put them on, the stripped out on the second wheel and because I bought them over the winter (Summer wheels) and didnt install them till last month I had NO WARRANTY. They only offer 60 days from purchase. JUNK
Old Apr 24, 2015 | 03:17 PM
HoldmyMouse's Avatar
HoldmyMouse
Do a Google search and you will see a lot of complains about their product fitment issues and poor quality. I also suggest you stay away and buy from reputable and proven companies. Suspension Parts are very very important.
Old Apr 24, 2015 | 03:29 PM
ChinkyChoy's Avatar
ChinkyChoy
Go with SPC
Old Apr 26, 2015 | 04:29 PM
buggzg37s's Avatar
buggzg37s
Thanks for all the info I decided to just go with the SPC rears!!!
As for the front from everything I have looked up since the H-techs don't do a drastic drop the stock setup should still be good for proper alignment. Right?
Old Apr 26, 2015 | 06:30 PM
The fronts aren't adjustable but are typically at the low range of spec from the factory so when you do a mild drop the alignment can still fall into the upper spec range (more negative camber) or at least pretty close. If you can fall into a couple tenths of spec then you should get reasonable tread wear as long as your toe is good.
you can even get just the SPC rear camber bolts & toe bolts rather than the rear arms, this total kit is about $50 but you'll have to elongate the camber slot along w/ the toe slot.
Here's the kits for the rear
http://www.spcalignment.com/componen...AFrom&to=USATo
Here's the camber & toe bolts (and they also fit G37s) you need 2 of these kits for the rear end.
http://www.spcalignment.com/index.ph...tion&pid=72265
And the on site vendor
http://thmotorsports.com/i-396790.as...FQ6OaQodCHwA4A
Kojack
Oct 9, 2015 05:53 PM
Allboutcali
Sep 26, 2015 03:43 PM
rgonz
Sep 11, 2015 04:07 PM
jfisher
Sep 9, 2015 04:17 PM
