stance coilovers
Old Feb 7, 2015 | 10:59 AM
Hdinh94092's Avatar
Hdinh94092
stance coilovers
I made up my mind getting the stance coilovers. I just can't come to a decision between the oem style and true type. I know the true type would be easier to adjust because its all one piece but I read somewhere it can be too much stress and not built like the oem style with the spring and strut separate. I heard the true type can later cause some noises and creaks.
Old Feb 7, 2015 | 07:26 PM
You can only get the "true" coilover setup w/ the Stance SS coils, there's some guys on the Z boards that have added some extra support to the upper shock mount so that might be something to consider, you'll probably be fine as a daily driver but if you plan on really pushing your car hard and tracking often then it would be a good thing to consider.
Old Jun 18, 2016 | 10:06 AM
G37fan09's Avatar
G37fan09
Hi I buying Stance coilovers next week, this is my first set of coilovers and I'm wondering if they come with springs for the rear control arm or I have to use stock springs.
Can someone help?
Thanks
Old Jun 18, 2016 | 01:16 PM
slartibartfast's Avatar
slartibartfast
You'll get springs with the dampers. Really, you should have asked the vendor or Stance this question.
Old Jun 19, 2016 | 12:27 AM
Ape Factory's Avatar
Ape Factory
Can someone help?
Thanks
What you should be asking is the rear spring in the OEM location or is it a true-type coil-over setup in the rear where the spring is mounted to the shock?
There are benefits to both depending on what your intended use is.
Stevolkz33
May 28, 2016 02:36 AM
BurtoN86
Nov 3, 2015 04:40 PM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
Edward Cheng
Sep 8, 2015 11:56 AM
