VDC/abs/slip light
Old Dec 3, 2014 | 10:11 AM
flipmode007's Avatar
flipmode007
VDC/abs/slip light
I brought my car to the dealer last week because the VDC/abs/slip light came on and they top it up with brake fluid and after 2-3 days the light came back. So this morning I had an appointment and they said the car showed so many code that they couldn't tell and would like me to bring the car in when the VDC/abs/slip light comes back on cuz they cant tell whats going on, and would like to do a diagnostic while it shows.
The dealership cleared all the code and said to come back when the vdc/abs/slip light come back again and my warranty on the car is over soon in less than 1500 km.
Anyone of you had encounter such problem??
tks in advance.
Attached Thumbnails VDC/abs/slip light-img_3460.jpg   VDC/abs/slip light-img_3461.jpg   VDC/abs/slip light-img_3462.jpg
Old Dec 3, 2014 | 02:20 PM
G37XSER's Avatar
G37XSER
Boy I wish I could help, but when that happened to me, adding more brake fluid took care of it. If you haven't already done so, search that problem on this forum and I'm sure you will come up with lots of ideas. Good luck, and keep us posted.
David
Old Dec 3, 2014 | 03:05 PM
flipmode007
Tks, for the response,
I brought the car to the dealership last week, they top it up with brake fluid and 2-3 day after it came right back, so I made an appointment for today.
I've search around and so far ts the break fluid on most and the sensor.
Old Dec 3, 2014 | 11:48 PM
vqsmile's Avatar
vqsmile
Aside from the usual suspects in these instances that you already mentioned, I'd have them make sure your battery/charging system is good, and that your brake pedal switch adjustments are all ok. These cars can go slightly insane when voltages are off, and I have personally seen a maladjusted brake pedal switch cause that trio of lights.
.02
Old Dec 4, 2014 | 12:33 AM
flipmode007
tks for the info, I will try to have it check it on Friday.
Old Dec 21, 2014 | 08:55 AM
flipmode007
here's the update, if anyone is having problem with the vdc light coming back after adding break fluid to their G ask the dealer to check the ASCD main switch, there's 2 of them, that may be the cause of it.
Attached Thumbnails VDC/abs/slip light-img_3519.jpg
Old Dec 21, 2014 | 12:31 PM
vqsmile's Avatar
vqsmile
Hmmm, what I'm seeing is that they are listing the part numbers for the ASCD brake switch and the stop lamp switch, both of which are down on the brake pedal (like I had mentioned previously), but neither are the part number for the cruise control switch on the steering wheel (i.e. the main ASCD switch). I find it unlikely that two switches would simultaneously fail on your brake pedal though. My guess is they had trouble adjusting them and just started shotgunning parts.
Congrats on getting it fixed anyway.
Old Dec 21, 2014 | 06:36 PM
skeener's Avatar
skeener
Any particular driving conditions which triggered this or just a constant on situation? TIA.
Old Dec 23, 2014 | 12:40 AM
flipmode007
It all happen in November, there was no snow on the ground when it first happen, I mostly do highway driving and when it first happen. I was doing 110km which is 68miles and all the light came on, some days the light will come on 10 min after and some day 30min after starting the engine or some days it will come back 2 days after.
They tried to put the blame on the automatic starter that I installed on the car.
Old Dec 23, 2014 | 03:49 AM
vqsmile's Avatar
vqsmile
Whoa . . . wait up; you normally have to have to depress the brake pedal to start the car, right? So, if you had a remote starter installed, wouldn't it have to have some way around that? Maybe it actually could be involved.
Old Dec 23, 2014 | 08:24 AM
flipmode007
Actually, all those light came on way before the automatic starter was installed.
I don't think we depress on the brake pedal before starting...rather press on the brake
Old Dec 23, 2014 | 08:55 AM
ttv36's Avatar
ttv36
Race, repair, repeat.
Could be an air bubble in the brake lines have them flush the brake fluid.
Old Dec 23, 2014 | 12:07 PM
vqsmile's Avatar
vqsmile
Could it have been two problems though; with the topping off of the brake fluid initially fixing the first cause, and then the remote starter install creating the second (and separate) problem?
But depressing the pedal is what presses the brake (and triggers those switches).
Please explain.
Old Dec 26, 2014 | 11:43 AM
flipmode007
Please explain too
[QUOTE=vqsmile;3857447]Could it have been two problems though; with the topping off of the brake fluid initially fixing the first cause, and then the remote starter install creating the second (and separate) problem?
When it first happen I thought it was because the tread depth on my summer tires were not even.
posted by GAWD " G37X & its all wheel drive system really should have matching tread depth on all 4 corners. How much tread is on the back tires? So what ever tires you just put up front, go get a pair for the rear. Like soon... Brake light very well could be low brake fluid."
So I went an install my new winter tires but the problem came back lol.
Its been over a week and the Lights never came back
lol
Gefartenblatz
Nov 10, 2015 11:45 AM
MEH2013G37
Sep 24, 2015 08:37 AM
pcwd
Sep 15, 2015 10:06 PM
CasperG37
Sep 14, 2015 07:46 PM
B Feelgood
Sep 13, 2015 05:56 PM
