Do we really need a camber kit for TEIN lower spring?
Old Sep 7, 2014 | 08:35 PM
Jas37s's Avatar
Jas37s
I currently have middle drop on my G and want to have more aggressive look so I'm looking at the Tein lower spring but not sure if I have to have a camber kit and is it better than Eibach?
Old Sep 7, 2014 | 08:49 PM
cecrops's Avatar
cecrops
I had to get front and rear control arms plus toe bolts for my tein h-techs to get into spec. thought i could get away with only rear arms then i had to install the fronts shortly after.
I've never driven on eibachs but so far I love the teins
Old Sep 7, 2014 | 09:03 PM
Jas37s's Avatar
Jas37s
I'm on Eibach now and pretty much like it. at first I planned to get a body kit but now change my mind so need to drop a little more. but honestly - is that a MUST to install the camber kit?
Old Sep 7, 2014 | 10:21 PM
Sway_NV's Avatar
Sway_NV
I'm too young to die!
I had eibachs on my 00 Prelude with Koni yellow shocks back in the day. It was decent, but a little floaty for my tastes... I've never had Tein springs, but I did have Tein Coilovers on my RSX and I absolutely loved them! They were amazing in every way... As for camber kits, you really SHOULD get them with any drop. Highly recommended. Your tires and wallet will thank you later. I had a slammed gs300 that loved to eat through tires ever 4k miles... "Hella" camber and all... Way over that now. At least get the rear kit if not front and rear.
Old Sep 7, 2014 | 10:59 PM
Your alignment w/ your Eibachs will be out of spec w/out camber kits, even more so w/ deeper drop springs. So in short, I'd get the kits w/ your current setup and a must w/ more drop.
Old Sep 8, 2014 | 01:54 AM
G37Sam's Avatar
G37Sam
Doesn't take a lot of lowering on our cars to get them super out of spec. Unless you want to deal with the headache of flipping tires around.
Old Dec 27, 2014 | 09:59 AM
Sunofabeach's Avatar
Sunofabeach
I wouldn't go with Tein s-tech, i've had them for about a year and have to change tires every 2-3 months on the rear. I also have a spc rear camber kit and spc toe bolt kits and it still eats through them
Old Dec 30, 2014 | 03:54 PM
epenbecks's Avatar
epenbecks
i just install the S-tech few weeks ago and i like how it looks... and looks nicer with 20" rims it fit perfectly!
BEFORE!
AFTER!
20" RIMS!
Old Feb 3, 2015 | 04:00 PM
veils1de's Avatar
veils1de
how do you like the ride quality of the s techs? looks like camber kits will be a must whether you go eibach, h tech, or s tech, so the only difference is drop and ride quality. i have s techs on the way but debating whether to keep them
BEFORE!
AFTER!
20" RIMS!
Old Feb 3, 2015 | 05:02 PM
epenbecks's Avatar
epenbecks
I didn't feel big different for the ride quality. and also i don't use any camber kits on my car. i'm using 245 front and 275 rear for the tires.
Old Feb 3, 2015 | 07:21 PM
Check your tire wear over the next few thousand miles, it's not going to be pretty.
Old Feb 3, 2015 | 09:04 PM
NewG's Avatar
NewG
You will need a camber kit when using Tein S Tech springs. I just installed mine and I had to buy both front and rear camber kit. Much better now!
Old Feb 3, 2015 | 09:51 PM
veils1de's Avatar
veils1de
would you mind linking me to the kits? i checked on sites and i see a bunch of different products. not sure which ones i need. thanks
Old Feb 3, 2015 | 11:16 PM
NewG's Avatar
NewG
I bought the Eibach kit. Front control arms and rear camber arm with bolts.
Old Feb 3, 2015 | 11:21 PM
The Eibach is the same as the SPC sets. Check w/ Luke at THMotorsports for good deals.
https://www.myg37.com/forums/brakes-...torsports.html
