Heavy front end, sloppy handling...
Old May 30, 2014 | 07:26 PM
Originally Posted by CodeG
But I know what I am doing, been there done that.
...and can you start the car with just one battery?
Old May 30, 2014 | 07:55 PM
Lego_Maniac's Avatar
Lego_Maniac
Old May 30, 2014 | 10:05 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Internet troubleshooting works... Really it does...
Old May 31, 2014 | 02:19 AM
CodeG's Avatar
CodeG
For the G37, I don't know if a single trunk mount would sufficiently starts the car. In the past, after moving the battery to the trunk, I had to use 2 batteries to start my 5.0
Is that clear enough?
Old May 31, 2014 | 02:24 AM
HoldmyMouse's Avatar
HoldmyMouse
So to improve handling, you added more weight?
Old May 31, 2014 | 02:25 AM
CodeG's Avatar
CodeG
Nah.. mostly clueless jumping the gun.
Old May 31, 2014 | 07:17 AM
Not exactly.
To improve handling, he relocated the battery.
He added another battery to start the car.
Ipso facto, he improved handling by starting the car.
Old May 31, 2014 | 07:40 AM
Chris11LE's Avatar
Chris11LE
What size wire did you use after moving the battery? If car X starts on battery Y when its under the hood, why wouldnt it start on battery Y when its in the trunk?
Only things I can think of that would cause it is if the battery isnt charging (i.e. wasnt relocated correctly) or the wire between battery and starter cant carry the amperage (i.e. incorrectly sized cables)
There are plenty of battery relocation kits out there, none of them require a second battery.
Old May 31, 2014 | 07:41 AM
Chris11LE's Avatar
Chris11LE
Not exactly.
Cool! Im going outside right now to start and stop my car about 20 times. Should be an F1 racer by then, right?
As an aside, didnt Infiniti mount the battery close to the windshield area for better weight distribution? (i.e. better handling)
Old May 31, 2014 | 09:49 AM
mathnerd88's Avatar
mathnerd88
Don't feed the troll.
Troop12
May 9, 2018 02:40 PM
m3clubracer
Sep 11, 2016 09:01 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
ddayeg37s
Aug 9, 2015 07:10 PM
