Are springs hard to install
Old Mar 21, 2014 | 07:24 PM
jdubg37's Avatar
jdubg37
Has anyone installed their own springs on the G ? How was it easy ?
Old Mar 21, 2014 | 07:33 PM
Gwhizz's Avatar
Gwhizz
Not if you have a basic understanding of how the suspension works and follow standard safety practices.
Old Mar 21, 2014 | 07:54 PM
Gio37's Avatar
Gio37
They are somewhat easy but time consuming...the front are a little harder to install and they could also be dangerous.
Old Mar 21, 2014 | 08:04 PM
Pretty easy if you've done some wrench twisting. The 19mm lower strut bolt is the killer but w/ PB blast a 2ft breaker bar and a 21mm back up wrench (on the nut on the back of the 19mm bolt) it's pretty easy. Just be sure to either use decent "rental" compressors from Autozone/O'Reillys or take the struts to a shop to swap the springs out once they're removed from your G. If you use the compressors be sure to grease the threads heavily and use an air impact gun on the bolts to compress the springs. Also need to make a mark for the top strut hat orientation, this needs to be mounted in the same position w/ your new springs. Also a good time to install your camber/toe kit as I really wouldn't recommend dropping w/out them.
Old Mar 23, 2014 | 08:44 PM
Jack10525's Avatar
Jack10525
Hey blnewt wouldn't a camber kit only be required for springs lower than 2" drop? I thought the swift and eibachs don't need camber kits.
Old Mar 23, 2014 | 10:23 PM
That's a topic I've gone back & forth with. Some get by without them and are able to get close enough to have reasonable wear and others have rapid tread wear. IMO the camber sets pay for themselves long term in tire purchases and being able to have your car aligned properly in spec.
I used to be of the mindset to get it close enough and just deal w/ a bit faster wear and alignment a bit out, but I don't think $500 is much to pay to have it right.
Old Mar 23, 2014 | 11:05 PM
Gio37's Avatar
Gio37
^+1
I didnt want to install the Eibach kit without the f/b camber kit
Old Mar 23, 2014 | 11:39 PM
quakerroatmeal's Avatar
quakerroatmeal
Depends how friendly your nuts/bolts are on your car. It can be easy, but don't start wrenching thinking it'll be all smooth.
G's
Nov 5, 2023 12:01 PM
si_driver
Aug 23, 2017 01:35 PM
xstarpro
Jan 19, 2016 07:15 PM
james6980
Oct 9, 2015 01:28 PM
blazeplacid
Sep 17, 2015 10:50 AM
