front brake DIY
My favorite trick is being more specific about what you are "DIY"-ing on your front brakes. Changing pads? switching from regular brakes to big brakes? changing the rotor? bleeding the lines? adding stainless lines? Painting the calipers?
I see! In that case, here is a DIY for you:
https://www.myg37.com/forums/d-i-y-i...37s-video.html
and after you're done, bed your brakes:
https://www.myg37.com/forums/brakes-...and-video.html
Tips:
Make sure your clean out the sockets where the brake pads go while you're in there. You want as little grease as you can, get some brake cleaner and use it. Try to keep it off your paint.
Tips:
Tips:
Tips:
LOL I studied that video so many times before I did mine and then when I took off my wheels, I didn't see that panel. At the time, I thought that the brakes were the same even though my xS didn't have the akebonos...
Peter Reynolds
Aug 6, 2015 07:53 PM
