Handling Issue with braking wobble
Old Feb 27, 2014 | 07:10 PM
bat6wc's Avatar
bat6wc
I have the OEM non-sport brakes with stop-tech pads. Recording will be tough with just my phone and with the road noise. Im at 75000 miles
I guess Ill have to get by until wed. thats when my dealer appt is.
Old Feb 28, 2014 | 08:55 AM
TVPostSound's Avatar
TVPostSound
This might be obvious, but have you rotated the tires?
Put the new ones on the front to see/hear any difference??
Old Mar 31, 2014 | 10:09 PM
bat6wc's Avatar
bat6wc
UPDATE!
I ended up replacing the front calipers and front rotors. I believe one of the pistons in the front left caliper was faulty and not engaging properly. The rotor was warn unevenly with a good size nick/cut going vertically with pad skipping marks after it. I also did a full rotate and balance on the wheels/tires.
While I was at it, I removed and refilled the power steering fluid reservoir, differential fluid change and transfer case fluid change.
Result, things are much better and back to normal. I still hear a thud thud thud noise from the wheels lightly when turning but I dont think its wheel bearing related. I believe its just the tread of the tires (Continental XtremeContact DWS). I was ready to sell the car, and now I may just hold on a little bit longer.
Old Mar 31, 2014 | 10:27 PM
Yazovets's Avatar
Yazovets
My mechanic says that a few cars have known issues with the brake rotors - especially the front ones. Toyota Camry, our G37, etc are known to easily warp the surface of the front rotors which causes shuddering or pulsating when you brake light to medium.
As for the tires, I run Continental PureContact DWS in the summer - a fantastic choice.
Old Apr 1, 2014 | 03:24 PM
G37XSER's Avatar
G37XSER
Boy does the shudder problem hit home. Mine does it pretty bad in the front at 63,000 miles. I will have to check out the rotors here soon when a little more snow is gone...I hope. Sometimes it's so bad, it feels like the front tires are going to jump off and abandon ship.
David
Old Aug 13, 2014 | 11:49 PM
Jokr__'s Avatar
Jokr__
Have the exact exact exact same problem. Can you please help?
Originally Posted by bat6wc
I cannot figure out what the deal is with this car. The front end just does whatever it wants to do. It will do straight and solid for a little bit then pull hard to the left, or sometimes right. The turning at high speeds feels very unstable and the short, quick turns from left to right and right to left make the car feel like its going to flip and crash. I also just started getting a very noticeable vibration in the front wheels when braking at high speeds. Steering wheel wobble and there is a judder in the pedal. The rotors are 6 months old with good pads (I previously had just the high speed brake judder and replaced the rotors which temporarily solved it). The car feels dangerous to drive. Ive checked alignment, balancing, loose/broken parts, etc. Would a wheel bearing cause this? When I turn my turn my car slowly to the right, I do hear a mild rotational tire noise. I have brand new tires on the rear and the front tires have 50% tread. They have all been balanced with same issue.
Any thoughts?
It's my 10th car. 3 of those 10 had bridgestone and did almost the same problem ; nissan maxima 2005, audi s4 2001 and my G37s coupe 2008 that I have now. I had the original tires size on the 19". Switched the back tires to the front and added 285/35zr19 on the back (19x9) with ContinentalContact2.
Front : Bridgestone REwtv 245/40r19 (19x8.5)
Rear : 285/35zr19 on the back (19x9). It fit without any problem. Still doing the same exact problem as you. Even my rotors and pads are brand new since 1500k ago (stopstech parts) and my disc started shaking after 200-300k) maybe I'm having the same issue with one the akebenos caliper. So please help. Always making inspection everytime I do some maintenance. Everything seems legit. bought new continental sportcontact2 (255/40zr19 for the front) hope i fix the problem. Did an alignement 3000k ago didn't change a thing.
Old Aug 13, 2014 | 11:50 PM
bat6wc's Avatar
bat6wc
Well I finally solved my problem. After replacing the driver side front caliper and the front rotors and pads, then swapping out wheel bearings, the car runs like it should. Im content...for now.
Old Aug 14, 2014 | 09:25 PM
acesk8er's Avatar
acesk8er
+1
Brakes are definitely not our cars' strong point. I've owned mine for a little over a year and I've already had the front rotors turned twice in ~25k miles due to shuddering. Any advice about a permanent fix is welcome.
Old Aug 15, 2014 | 01:53 AM
bat6wc's Avatar
bat6wc
Originally Posted by acesk8er
+1
I actually determined several months ago that my front driver side caliper was faulty, so i replaced it with a '12. I think the previous caliper was distributing uneven pressure on the pads due to a bad piston causing the warping of the rotor. So far with that and the new bearing, everything seems pretty good.
Old Aug 15, 2014 | 10:04 AM
Thirty_Seven's Avatar
Thirty_Seven
How were you able to determine the caliper wasn't working properly? My car has been doing the same thing.
Old Aug 15, 2014 | 12:05 PM
bat6wc's Avatar
bat6wc
The rotor had several marks indicating the caliper was seizing, the pads were also had uneven wear.
Old Aug 15, 2014 | 12:10 PM
Thirty_Seven
Hmm ok, I'm gonna go give everything a look over today. Thanks for the info
redlinernyc
Feb 29, 2016 11:06 PM
tomro99
Nov 17, 2015 02:08 AM
ZachThomas
Sep 3, 2015 01:40 PM
TVPostSound
General Tech Questions
Sep 2, 2015 04:09 PM
Mattlorentzoe
Aug 21, 2015 03:54 PM
