Stainless Steel Brake Lines + Akebonos
I'm putting together a brake upgrade kit for my X sedan and want to add in a set of SS lines. It seems like I have a couple options: Goodridge, Z1, and Stoptech. From what I'm reading, it looks as if Goodridge is the most popular option.
My question is as follows:
Because I'm installing the Akebono calipers on my sedan, do I buy a SS line kit that is made for a coupe or for a sedan? I'm a little bit unclear on this aspect, and I want to ensure I order the right set of lines so I don't get stuck in the middle of an install.
Thanks for any help you guys can provide!
Hey, I can help with this! I've got a sport coupe and have been deciphering all the different kits out there. My two main options are Goodridge and StopTech (these are what my what my favorite vendor offers *cough* ZSpeedPerformance!).
Cars that came stock with the Akebono
In the front and rear, these cars come from the factory with rubber hose that connects to a hard line sticking out of the caliper. So the order is hard line at the fender > rubber hose (in the wheel well) > hard line starting near the knuckle that attaches the caliper.
The Goodridge kit provides SS lines that replace the stock rubber line only (i.e. the ss line goes from the hard line on the fender wall to the hard line that is attached the caliper). I believe the Z1 kit is the same, however I haven't looked into the Z1 option too much.
The StopTech kit provides an SS line that replaces the stock rubber line and the hard line out of the caliper. Further, the StopTech Kit uses a different routing and mounting method (no brass blocks, just clamps on the line). This line is a long stainless steel braided line with a few clamps on. The routing is not ideal in my opinion.
Cars that came with the base model brakes
In the front, these cars came with a rubber hose from the fender to the knuckle, a hard line on parts of the knuckle and a rubber line to the caliper. Rubber > Hard > Rubber > Caliper.
All the kits replace the entire front segment (rubber, hard, rubber) from the fender wall, to the caliper.
I am not sure of the routing for the Goodridge kit.
The StopTech kit provides a single SS line that replaces the entire segment. The routing isn't particularly nice.
In the rear, the factory setup is a rubber line from the fender to the caliper.
I am not sure what any of the kits do here.
My recommendations:
If your Akebono BBK comes with the hard line sticking out of the caliper, you should purchase the Goodridge sport kit for sedans (I recommend Goodridge as the routing is close to stock, and it makes use of the hard line; I'll be going this route soon).
If your Akebono BBK does not come with the hard line and you find it difficult to obtain these hard lines, you should a StopTech kit for the sport sedans. This will come with the right hardware to mount to the Akebono and the lines are long enough as to replace the hard line into the caliper.
Other notes:
If you buy a kit that goes directly to the caliper, be aware that the banjo bolt is different (length and perhaps threading too) on the stock and Akebono calipers. Akebono calipers require a shorter banjo bolt!
Hard line part numbers (from 2008 Sport Coupe):
46246-JK60B left front
46245-JK60B right front
46315-JL00A right rear
46316-JL00A left rear
Links/References:
370z isntalling StopTech Lines, good pictures of the routing used I do not like how the lines are between the rotor and knuckle, I prefer them to be behind the knuckle (as per the stock design).
The FSM for the coupe, BR-21 has an overview of the piping layouts for the base/sport brake piping. It will help you understand what is being replaced.
My recommendations:
Other notes:
Links/References:
Wow thanks for all this valuable information. I'm assuming since I have the base model brakes now, and am swapping to the Akebono caliper option, I should get something for the sedan once I figure out if my calipers have this hard line attached to them, yes?
I have already purchased the correct banjo bolt for the Akebono caliper - 17mm M10x1.0 versus the 20.3mm one that is included on base calipers.
Thanks for the Details Dough, I copied your info on a sticky thread in the brake section so others will have easy access to it, nice job!
https://www.myg37.com/forums/brakes-...line-info.html
Dough1397 (02-13-2014)
I too want to upgrade to the Akebono brake set for my X sedan. Thanks for the great info. I am assuming after getting the correct banjo bolts for the calipers, the stoptech SS kit is the best option upgrading from the base brake calipers? Also is where is a good place to get those banjo bolts. I am assuming its 4 of them, one for each caliper?
Regarding the Banjo bolts, I picked mine up from Nissan as the 370z has the same calipers as the G37 coupe sport models. AND surprisingly, they're cheaper at the Nissan dealership near my house, versus the Infiniti dealerships.... DAFUQ is that?
I guess you could just get the Stoptech SS kit from the start. That way you'll have fresh lines from the fender area, all the way to the caliper. I may do that as well. Seems like the best route to follow.
The fitment of the StopTech lines are not so great. The brake lines will eventually loosen up and move out of it's original shape. The plastic sleeve that covers the lines have started to get eaten up by the passing of the wheels weights. The performance shop I go to had to push the lines back so it won't get caught up again. It would have been a big problem if the braided lines broke.
Go with Goodridge because it connects to some of the OEM parts already equipped.
