Painted my Akebonos!
Old Jan 25, 2014 | 07:20 PM
Xenolith666's Avatar
Xenolith666
Looks good OP... questions
600 grit sand paper? what was the primer you used? how many coats of all paints used? please and thanx
Old Jan 25, 2014 | 08:06 PM
FRChilln's Avatar
FRChilln
600 Sanding Block just to ruff up the surface and take off any grime.
Some generic high temp primer and 4 coats base and then apply decals followed by 3 coats clear.
Old Jan 26, 2014 | 09:34 PM
kmchenry's Avatar
kmchenry
Think this would look good on blue slate? The burnt orange?
Old Jan 27, 2014 | 02:08 PM
KEG97's Avatar
KEG97
Just to jump in since I did my brakes over Christmas- I used the same process as most folks here:
Light sand
2-3 coats of primer
5-6 coats of Brake Paint
3-4 coats of this metallic effect paint
3-4 coats of clear coat.
I found that having a household fan directly on the brakes significantly improved the drying time. I did one brake (front and rear) at a time and got everything done over 2 days.
One more suggestion (and FRChillin did a great job on this) is to make sure you wrap up the rest of the brake nicely. I had a lil overspray on my brake pads and a lil spot on my garage floor.
Old Jan 27, 2014 | 02:30 PM
quakerroatmeal's Avatar
quakerroatmeal
Did you paint the back side? Just curious if anyone who painted them on the car has painted the back side as well.
Old Jan 27, 2014 | 03:18 PM
FRChilln's Avatar
FRChilln
I painted as much as I could see with them still on the rotor. When new brake pads and drilled rotors are needed I'll take them off and strip them with aircraft carrier remover for a more professional finish but for the mean time they look great.
Old Jan 27, 2014 | 08:20 PM
guy from norcal's Avatar
guy from norcal
very nice. i like it
Old Jan 27, 2014 | 09:13 PM
Tunerz_Store's Avatar
Tunerz_Store
Parts Specialist
Nice job!!
ck1109
Oct 15, 2015 11:06 PM
faze2988
Oct 7, 2015 12:05 AM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
VIVID
Sep 27, 2015 09:45 AM
Allboutcali
Sep 26, 2015 03:43 PM
