Help rear toe adjustment kits?
Old Nov 2, 2013 | 03:43 PM
boelee's Avatar
boelee
hey guys I installed kw v1 coils on my g37s. And also got spl rear camber kit to correct the rear camber angle. But tire shop couldn't get the rear camber back into factory spec. Mechanic says they were trying to go positive camber but the toe went off. So current rear camber is -2.8, -2.2 on left and right.
My car is dropped mild like an inch or so. Seems like spl rear camber kit does not comes with toe bolts neither require drill job. Do you guys think rear toe kit is needed in this situation? It is really bugging me out since I dropped my car.
Old Nov 3, 2013 | 11:39 AM
Something doesn't sound right, w/ a mild 1" drop and having the camber arms they should be able to get the camber much better w/ the toe in spec. If you were dropped lower than I'd say the toe kit would be req'd. If you don't plan to go lower in the future than you should be OK w/ just the arms, but I'd be sure to get them if you do want to drop it more. Might also find another alignment shop or take it back and have them show you why they can't get it better.
Old Nov 3, 2013 | 05:03 PM
boelee's Avatar
boelee
tireshop says that camber and toe got connected and they were able to get toe in spec but not camber still remain negative. I don't understand either. I know that alignment depends on mechanic. Thank you for your help blnewt!
Old Nov 3, 2013 | 06:58 PM
deep007's Avatar
deep007
the SPC rear camber arms does come with the toe bolts if you bought em brand new.
Majeed Bader
Oct 8, 2015 10:52 AM
Ipp391
Aug 28, 2015 09:27 AM
ohmyg1990
General Tech Questions
17
Aug 13, 2015 08:18 AM
