g37 coupe true coil overs
Old Oct 27, 2013 | 05:08 PM
Juju0817's Avatar
Juju0817
hi I'm kinda a newbie to this but i just installed ksport true coil overs and i want to remove the useless spring bucket/perch but of coarse i need help lol what do i need to buy? is it just the toe arms or will the rear camber kit do the same job?or do i need both
Old Oct 27, 2013 | 05:43 PM
GET_SOME's Avatar
GET_SOME
I have the same k sports and i removed the buckets. I replaced them with spl rear toe bars.
Old Oct 27, 2013 | 05:46 PM
JC-RH's Avatar
JC-RH
I have a question on this too. I know they offer toe bolts or toe arms for our cars. If i want to avoid having to elongate the hole for the toe bolts, can I just go with toe arms? If the answer is yes, do the arms just replace the spring bucket? How does that part of the setup work?
Old Oct 27, 2013 | 05:58 PM
Juju0817's Avatar
Juju0817
Yea i seen those but was still wondering can ijust go with the rear camber and remove the bucket or would i need both to do this
Old Oct 27, 2013 | 08:11 PM
TVPostSound's Avatar
TVPostSound
The toe arms relace the spring buckets in true coilover installs, they are adjustable in the same fashion as the toe arms.
Youll need lock out plates too!
Old Oct 27, 2013 | 11:36 PM
GET_SOME's Avatar
GET_SOME
If you renove the rear bucket and dont put anything back in its plate the rim will move around on you
superjoey
31
Mar 22, 2023 11:56 PM
Dsskyline
ECU Tuning / Dyno Data
91
Oct 9, 2016 01:24 PM
BANNISTER
Dec 10, 2015 04:14 PM
JoshB
Oct 15, 2015 03:08 PM
