G37S Brake Pad Harware
Old Oct 28, 2013 | 10:56 AM
infinitiman96's Avatar
infinitiman96
G37S Brake Pad Hardware
I need to replace my rear brake pads on my 08S coupe and had a question about the hardware which comes with the pads. I want to buy some Akebono Pads from tirerack but it looks like they dont come with replacement hardware. Is it okay to reuse the oem slide pins and clips?
http://www.tirerack.com/brakes/brake...ar=Sport+Model
Old Oct 28, 2013 | 11:12 AM
canucklehead's Avatar
canucklehead
No problem. The pads will come with new backing plates and copper grease which is all you need. Just give the old pins and spring clips a good cleaning and grease where you need to. In fact give everything a good cleaning while you are in there. I have the Akebono proact pads and they are good.
SBG37
Mar 12, 2021 03:16 PM
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
zero260
Aug 12, 2015 10:02 AM
Peter Reynolds
Aug 6, 2015 07:53 PM
