Need help lowering 2010 37S
Old Oct 5, 2013 | 08:18 PM
Crouse27's Avatar
Crouse27
I would like to put some 20's on it and also lower it no more than an 1". Would eibach springs work? Or do I need to go with coil overs?
Old Oct 5, 2013 | 08:41 PM
BluestickG's Avatar
BluestickG
Yeah those will be fine
Old Oct 5, 2013 | 10:42 PM
dkmesa350z's Avatar
dkmesa350z
check out swift springs. drop no more than an inch and great ride quality and handling.
Old Oct 6, 2013 | 12:21 AM
Need 4 Speed's Avatar
Need 4 Speed
Id go Swift over Eibach... just my. 02˘ though coils are much better which I have now
Old Oct 6, 2013 | 12:52 PM
Himalaya's Avatar
Himalaya
I have eibach and 20s... It still seems a little too high, and i wish i went with coils the first time. If coilovers are in your budget, I would go with them.
With my eibach and 20's, the front end is fine, but theres a huge gap in the rear now that i didnt have with my 18s. It could be because i am running a low profile tire in the rear now, but I will be getting coils in the future.
BTW, ride quality sucks on the eibach, i dont know what to say about swift springs, because i never had them, but I would think its a waste of money because with 20s on swift springs, its going to look horrible because there will be a very big gap.
Old Oct 6, 2013 | 02:26 PM
If there's a huge gap w/ your 20s that you didn't have w/ your 18s that's all in your tire sizing. If you kept the diameters the same (which you should to keep the ABS, Traction Control and speedometer in range) the gap will be the same. If you had 245/45/18s you should now be running 245/35/20 for example.
But agreed about the coils, it's worth the extra coin to have the height and feel exactly where you want it.
Old Oct 8, 2013 | 01:39 PM
inknartg37's Avatar
inknartg37
I never even really thought of doing this!
The eibachs look perfect int he front with the tire sizing and drop however the rear have a huge gap now.... Maybe I should just go with a biggier tire to offset the gap and bring everything flush again?
Thoughts?
Old Oct 8, 2013 | 02:10 PM
Thoughts?
As long as your new tire diameter is close to the stock diameter, use the tire calculator to figure it out. Want to be at least within 3% of your oem but less than 1% is ideal.
PearlPereZ
Jun 21, 2016 06:35 PM
cconklin2
Jan 9, 2016 07:21 PM
jfisher
Sep 9, 2015 04:17 PM
harlemcat45
Sep 9, 2015 09:35 AM
