torque value for fork under strut on g37x?
Old Sep 13, 2013 | 08:03 AM
chris_s's Avatar
chris_s
Hello, looking to install springs soon. The only bolt that looks like it has an important torque value is the one across the bottom of the fork that spans the front axle
anyone happen to have it? I found a service diagram but it was rwd only so that bolt/fork doesn't exist
Also can anyone confirm the rear LCA bolt is 53#? I'd seen that posted elsewhere...
thanks!
Old Sep 13, 2013 | 08:47 AM
thanks!
Here's the only FSM I could find for 2009, not sure if the AWD is included though?
Index of /FSM/G37/Sedan/2009
Old Sep 13, 2013 | 10:06 AM
chris_s's Avatar
chris_s
NICE full FSM
there are two sections labelled [2wd] and [awd] so the right specs are in there
just to confirm, the bolt is labelled "92 (9, 4, 68)" so that means 92 lb/ft? That sounds about right, based on my previous work on other vehicles.
what is the 9, 4, 68 about?
thanks
Old Sep 13, 2013 | 10:04 PM
NICE full FSM
thanks
Pg 5 of the GI (General Information) section of the FSM will detail the Torque values & symbols
http://www.nicoclub.com/FSM/G37/Sedan/2009/GI.pdf
First value is Newton-meters (outside the parenthesis) then kg-m and finally Ft. lbs., so in short the last number is foot lbs or inch lbs depending
on the symbol that goes w/ it.
jfisher
Apr 25, 2017 01:22 PM
Mattlorentzoe
Sep 14, 2015 07:32 PM
misc
Sep 11, 2015 03:53 PM
Falker11
Sep 9, 2015 08:53 PM
xpcgamer
Sep 7, 2015 07:10 PM
