Unless you are also planning to move to a larger wheel you might be better off just doing an upgrade to Brembo or somethingb similar.
If you want the full Infiniti set-up you'd be better off just getting a car originally equipped with it.
I have 19" wheels on my sedan without the sport brakes but Id like to get larger rotors to fill out the wheels (for a better appearance). It should be cheaper than upgrading to brembo or buying sport brakes to put on
It doesn't work this way. You can't just get bigger rotors for your current brakes. You'd need to buy the sports brakes package in order to get bigger rotors.
Right; the larger rotors wouldn't work with your current calipers.
